-   -   Warning from checkMesh is this serious (http://www.cfd-online.com/Forums/openfoam-solving/59203-warning-checkmesh-serious.html)
hsieh January 8, 2008 10:40
Hi, When I issued checkMesh
When I issued checkMesh to check my mesh, I got:
***Faces not in upper triangular order
<<Writing 1 unordered faces to set upperTriangularFace
Topological cell zipup check ok
Failed 1 mesh check.
Can anyone explain what this means? Thanks!
Pei
lr103476 January 8, 2008 10:55
The order of the faces is only
The order of the faces is only important for convergence rate of the linear solver. Use renumberMesh to reorder the faces and this message will be gone....
Frank
hsieh January 8, 2008 11:35
Hi, Frank, Thanks for the q
Hi, Frank,
Thanks for the quick respond!
According to the warning message, there is only 1 face that is unordered. When I issued "renumberMesh . case", and then checkMesh, I still got the same warning. Did I use the renumberMesh util correctly?
Pei
lr103476 January 8, 2008 11:49
Mmm, that's the way to use it,
Mmm, that's the way to use it, works fine here....
fra76 January 8, 2008 11:50
I had the same problem. As fa
As far as I know, that warning is just a small bug in the current checkMesh (1.4.1).
Using renumberMesh, however, can imporve your simulation time a lot!
Francesco
hjasak January 8, 2008 12:15
There's no bug: mesh face orde
There's no bug: mesh face ordering is strictly enforced and necessary for good performance of Incomplete Cholesky preconditioning. Just run renumberMesh and it will get fixed.
Hrv
fra76 January 8, 2008 12:25
Hi Hrvoje, that's what I mean
Hi Hrvoje,
that's what I mean. Even after renumberMesh, the error from checkMesh doesn't disappear. The same happened to Pei.
Francesco
hjasak January 8, 2008 13:05
OK, look at it here: sit in a
OK, look at it here: sit in a cell, visit all neighbours, ask for a cell neighbour label and pick out the smallest one. No error here:
// Add the faces in the increasing order of neighbours
for (label neiSearch = 0; neiSearch < nNeighbours; neiSearch++)
// Find the lowest neighbour which is still valid
label nextNei = -1;
label minNei = oldCells.size();
forAll (neiCells, ncI)
if (neiCells[ncI] > -1 && neiCells[ncI] < minNei)
nextNei = ncI;
minNei = neiCells[ncI];
if (nextNei > -1)
// Face is internal and gets reordered
reverseFaceOrder[curFaces[nextNei]] = nMarkedFaces;
// Stop the neighbour from being used again
neiCells[nextNei] = -1;
nMarkedFaces++;
else
FatalErrorIn
"fvMesh* fvMeshBandCompression::renumberedMesh() const"
) << "Error in internal face insertion"
<< abort(FatalError);
I bet you've got 2 cells sharing more than one face - that is not allowed.
Hrv
schmidt_d January 22, 2008 23:12
Gents, There are a few ways
Gents,
There are a few ways I could imagine two cells end up sharing a face. Some of them involve seriously non-convex cells. However, if you just have some degenerate edges, then collapseEdges might be worth a try. You have nothing to lose.
David
