-   -   RSMEARSM MSHA (http://www.cfd-online.com/Forums/openfoam-solving/59216-rsmearsm-msha.html)
msha October 7, 2007 05:40
Dear All Is there any RSM/E
Dear All
Is there any RSM/EARSM for turbulence in FOAM
IF not, how I can apply the method in code
any suggestions,reference , tutorial,...
Thank you all
msha October 9, 2007 07:43
Please help
Please help
david_h October 9, 2007 09:33
There are several RSM turbulen
There are several RSM turbulence models available:
http://www.opencfd.co.uk/openfoam/turbulenceModels.html
The "cavity" case in $FOAM_TUTORIALS/turbFoam can get you started. To change the turbulence model you will need to modify the "turbulenceModel" entry of "constant/turbulenceProperties".
You will also need to edit the "0/R" as described in the following:
http://www.cfd-online.com/OpenFOAM_D...tml?1191786770
Dave
msha October 15, 2007 11:02
THANK YOU David I'll refer
THANK YOU David
I'll refer to the sites
Best regards
MSHA
msha January 21, 2008 01:32
ARSM turbulence mode is added
ARSM turbulence mode is added to code
