RSMEARSM MSHA
Old   October 7, 2007, 05:40
Default Dear All Is there any RSM/E
Mojtaba Shahmohammadian
msha is on a distinguished road
Dear All
Is there any RSM/EARSM for turbulence in FOAM
IF not, how I can apply the method in code
any suggestions,reference , tutorial,...
Thank you all
msha is offline   Reply With Quote
Old   October 9, 2007, 07:43
Default Please help
Please help
Old   October 9, 2007, 09:33
Default There are several RSM turbulen
E. David Huckaby
david_h is on a distinguished road
There are several RSM turbulence models available:
http://www.opencfd.co.uk/openfoam/turbulenceModels.html
The "cavity" case in $FOAM_TUTORIALS/turbFoam can get you started. To change the turbulence model you will need to modify the "turbulenceModel" entry of "constant/turbulenceProperties".
You will also need to edit the "0/R" as described in the following:
http://www.cfd-online.com/OpenFOAM_D...tml?1191786770
Dave
david_h is offline   Reply With Quote
Old   October 15, 2007, 11:02
Default THANK YOU David I'll refer
THANK YOU David
I'll refer to the sites
Best regards
MSHA
Old   January 21, 2008, 00:32
Default ARSM turbulence mode is added
ARSM turbulence mode is added to code
msha solve Eqn programming in C using FOAM msha OpenFOAM Running, Solving & CFD 2 January 6, 2008 07:03
msha ADD A NEW RELATION TO kepsilon MODEL msha OpenFOAM 0 December 30, 2007 09:30
msha solve Eqn programming in C using FOAM msha OpenFOAM 2 December 30, 2007 02:39
Which Solver MSHA msha OpenFOAM Running, Solving & CFD 2 October 15, 2007 11:04
[blockMesh] MSHA mesh error msha OpenFOAM Meshing & Mesh Conversion 0 September 23, 2007 00:46
