I used buoyantSimpleFoam... wi
I used buoyantSimpleFoam... with a fluent mesh previously converted... I copy the solver and change some things, but I have these errors
--> FOAM FATAL IO ERROR : size 4000 is not equal to the given value of 210 file: /home/pcornejo/OpenFOAM/pcornejo-1.4.1/run/tutorials/buoyantSimpleFoam/prueba1/1 000/p from line 28 to line 4052. From function Field<type>::Field(const word& keyword, const dictionary& dict, const label s) in file /home/dm2/henry/OpenFOAM/OpenFOAM-1.4.1/src/OpenFOAM/lnInclude/Field.C at line 224. FOAM exiting ---------------------------- I don't know what change for second error.... plis help me... If speaks spanish... I will be grateful Thanks |
No spanish i'm afra
No spanish i'm afraid... I see only 1 error which is probably caused by the fact that you have 2 different mesh sizes. This can be caused for instance by running a problem with a certain mesh (ie 4000 cells) then changing your mesh to another size (ie 210) and not deleting your previous solution. (there are other ways to get this error to i think) Hope this helps... Simon |
thanks... I will check what yo
thanks... I will check what you say...
