November 27, 2014, 07:17 |
heat transference solid-liquid
Rep Power: 11 |
Good Morning!
Do you know what is the parameter which affects directly to the heat transference between a solid (for example T=400K) and a liquid (T=300K)?? I'm using the solver buoyantBoussinesqSimpleFoam. The model is defined right and the simulation works. The problem is that I don't see any heat transfer between the 2 elements, and obviously it should appear easily. I think it should be some of the properties of my liquid, but I don't know which one exactly. I have tested many things, changing every parameter which for me could have some relation with these problem (alphat, k, Pr, etc) I guess it is not a difficult question at all, but I don't achieve it. I can post you any file you need. Thank you!! |
November 27, 2014, 13:12 |
Kaufman
Rep Power: 12 |
What do you mean that there is no heat transfer between each other? Considering your case is about solid-liquid multi-region, it might be better to use chtMultiRegionSimpleFoam. https://openfoamwiki.net/index.php/G..._-_planeWall2D |
Display Modes | |
Radiation interface | hinca | CFX | 15 | January 26, 2014 18:11 |
Water subcooled boiling | Attesz | CFX | 7 | January 5, 2013 04:32 |
problem of heat transfer from a solid to a liquid | eugen2077 | OpenFOAM Pre-Processing | 2 | December 28, 2012 13:46 |
No results for solid domain | Gary Holland | CFX | 10 | March 13, 2009 04:30 |
Heat transfer from solid to liquid | Richard | FLUENT | 2 | January 30, 2006 05:10 |
