January 8, 2008, 09:26 |
Hello OpenFOAMers,
i'm new
Oliver Sommer
Rep Power: 17 |
Hello OpenFOAMers,
i'm new to OpenFOAM and i just practiced a bit with the "cavity"-tutorial. (i simply let OpenFOAM calculate it in 3D) Now i want to simulate a Rayleigh-Bernard-convektion in a tank. I want that i can set temperatures on the top and bottom of the tank and set the velocity-field U to zero and then simulate this Rayleigh-Bernard-cell. But now i don't really know which solver i have to use. I searched the manual (User Guide) and i found the following solvers: "rhoSonicFoam", "rhopSonicFoam", "rhoTurbFoam" and "rhoSimpleFoam". Out of the description (on the right hand side in the manual) i believe it would good to use the "rhoSimpleFoam"-solver, but when i want to create a case i can't find this solver ins the drop down menu of the solver-selection. Why i can't find it? Cause of that, i tried it with the "rhoTurbFoam"-solver. But here i have a next question. I chose the patchtype "fixedTemperatureWallFunctions" for the top and bottom and "adiabaticWallFunctions" for the 4 rest-patches and set the fields (U everwhere zero and two different values for bottom and top T). I set the other values to zero, cause i don't really know what they are (k, epsilon and R). Now, after looking in paraview the mesh and the values at time 0 (all seems ok), i started the simulation, but it immediatelly breaks with this error: #0 Foam::error::printStack(Foam:stream&) in "/home/sool/OpenFOAM/OpenFOAM-1.4.1/lib/linux64GccDPOpt/libOpenFOAM.so" #1 Foam::sigFpe::sigFpeHandler(int) in "/home/sool/OpenFOAM/OpenFOAM-1.4.1/lib/linux64GccDPOpt/libOpenFOAM.so" #2 ?? in "/lib64/libc.so.6" #3 Foam::hThermo<foam::puremixture<foam::consttranspo rt<foam::speciethermo<foam::hc onstthermo<foam::perfectgas> > > > >::calculate() in "/home/sool/OpenFOAM/OpenFOAM-1.4.1/lib/linux64GccDPOpt/libbasicThermophysicalMo dels.so" #4 Foam::hThermo<foam::puremixture<foam::consttranspo rt<foam::speciethermo<foam::hc onstthermo<foam::perfectgas> > > > >::hThermo(Foam::fvMesh const&) in "/home/sool/OpenFOAM/OpenFOAM-1.4.1/lib/linux64GccDPOpt/libbasicThermophysicalMo dels.so" #5 Foam::basicThermo::addfvMeshConstructorToTable<foa m::hthermo<foam::puremixture<f oam::consttransport<foam::speciethermo<foam::hcons tthermo<foam::perfectgas> > > > > >::New(Foam::fvMesh const&) in "/home/sool/OpenFOAM/OpenFOAM-1.4.1/lib/linux64GccDPOpt/libbasicThermophysicalMo dels.so" #6 Foam::basicThermo::New(Foam::fvMesh const&) in "/home/sool/OpenFOAM/OpenFOAM-1.4.1/lib/linux64GccDPOpt/libbasicThermophysicalMo dels.so" #7 main in "/home/sool/OpenFOAM/OpenFOAM-1.4.1/applications/bin/linux64GccDPOpt/rhoTurbFoam " #8 __libc_start_main in "/lib64/libc.so.6" #9 Foam::regIOobject::readIfModified() in "/home/sool/OpenFOAM/OpenFOAM-1.4.1/applications/bin/linux64GccDPOpt/rhoTurbFoam " I don't know what's wrong - i think i set not all variables in the fields and/ or somethings in the dictionaries wrong. Can you please give me a help? Thank you. |
January 8, 2008, 10:05 |
Have you tried "buoyantFoam" ?
E. David Huckaby
Rep Power: 17 |
Dave |
January 8, 2008, 15:56 |
Thank you for the hint Dave. I
Oliver Sommer
Rep Power: 17 |
Thank you for the hint Dave. I overread this in the manual. With the "buoyantFoam" it is working and with the "rhoTurbFoam" too. I found a really little (and stupid) error - made by me - in the field entries.
Display Modes | |
Is there any Particle dynamics Simulatin Software? | leaf | Main CFD Forum | 0 | June 7, 2006 08:08 |
cell velocity U and its cell face area | Chinayu | Siemens | 0 | May 6, 2006 23:44 |
unsturcture cell & cylinder cell Difference~ | lenson | Siemens | 1 | January 9, 2006 06:32 |
Marangoni VS Rayleigh-Bernard | Peter Nagy | FLUENT | 2 | January 12, 2004 10:53 |
Cell-vertex and cell-centered finite volume method | Praveen | Main CFD Forum | 4 | September 9, 2003 00:58 |
