-   -   How to access to faces of a patch (http://www.cfd-online.com/Forums/openfoam-solving/59251-how-access-faces-patch.html)
jaswi December 30, 2007 20:05
Dear OpenFOAMers Greetings
Dear OpenFOAMers
Greetings
I need the face list of faces belonging to a boundary patch. This is what I am doing:
label patchID = mesh.boundaryMesh().findPatchID("cylinder");
const polyPatch& cPatch = mesh.boundaryMesh()[patchID];
With the above code lines I can create a polyPatch and assign it equal to the boundary patch i need.
Please give me a clue on how to access the faces of this patch as I need to loop over these faces.
Thanks in advance
Best Regards
Jaswinder
PS: I am searching the posts simultaneously
jaswi December 30, 2007 22:16
Hi Forum Good Evening once
Hi Forum
Good Evening once again
I wanted to calculate the surface area of a patch. This is how I achieved the result :
label patchID = mesh.boundaryMesh().findPatchID("walls");
const surfaceScalarField& magSf = mesh.magSf();
scalar patchArea = 0.0;
forAll(cPatch, facei)
patchArea += magSf.boundaryField()[patchID][facei];
Info << "Patch Area " << patchArea << endl;
I checked it for a cylinder and it gives accurate result. I am sure that it can be done in a more elegant way. Experts please suggest.
Now the next step is to iterate over the faces of this patch and sum the area of only those faces where value of volume fraction gamma is positive.
Any suggestions are highly appreciated.
Wish you all a successful year ahead
Best Regards
Jaswinder
shivasub December 30, 2007 22:19
Jaswinder, you can access e
Jaswinder,
you can access each of the faces in this manner after getting specific patch.
forAll(cPatch, faceI)
//whatever you need to access here
regards
Shiva
jaswi December 30, 2007 22:55
Thanks Shiva Your profile s
Thanks Shiva
Your profile shows that you work with Multiphase Flows. That's a good news for me as I am a novice in this field and have been looking out for people who are experienced, especially within OpenFOAM community.
Kind Regards
Jaswinder
shivasub December 31, 2007 13:14
Hi Jaswinder, good to know
Hi Jaswinder,
good to know you are working in multiphase flows as well. I am still learning a lot about this.
you can use an if test in the for loop for checking faces with gamma > 0 .
forAll(cPatch,faceI)
if (gamma.boundaryField()[patchID][faceI] > 0)
//whatever you need to do.
This works, but am not sure how efficient this is and whether there is any other elegant workaround.
regards
Shiva
jaswi January 6, 2008 07:04
Thanks Shiva It works.
Thanks Shiva
It works.
Happy New year
Jaswinder
Marshak March 2, 2013 22:43
sum of areas of all faces of a cell
I have a similar problem to solve. I want to calculate, for each given cell in the domain :
Length= cell Volume / sum of areas of all faces of a cell
Can you kindly help me how can I code this.
fumiya March 3, 2013 02:59
How to loop over cell faces
Hi Marshak,
I think it is better to start another thread for being easy to search later.
Regarding your question, the following is my sample code:
scalar sumA = 0.0; //Sum of areas of all faces of a cell
const cell& cFaces = mesh.cells()[yourCellIndex];
forAll(cFaces, i)
    sumA += mag(mesh.Sf()[cFaces[i]]); //cFaces[i]: face label of a cell
scalar Length = mesh.V()[yourCellIndex]/sumA;
Hopt that helps,
Fumiya
PEM_GUY September 28, 2013 15:34
label patchID = mesh.boundaryMesh().findPatchID("NAME OF PATCH");
Info << "patchID = " << patchID << endl;
Info << "cPATCH = " << nl << cPatch << endl;
scalar AREA = gSum(magSf.boundaryField()[patchID]);
Info << "AREA = " << nl << AREA << endl;
You might find it more efficient to do the following, it will avoid the need for additional looping. There is also the Foam::max and Foam::min function when needed to only sum more or less than a given value.
Cheers
DH
Marshak October 1, 2013 05:06
Is this the procedure for boundary patches only? if yes then how about finding surface area of each internal mesh cell?
kiddmax December 4, 2013 05:37
Dear DH,
should I add this code into controlDict file? or the solver code?
PEM_GUY December 4, 2013 15:01
Faces... faces... everywhere...
The routine above works for addressable patches, i.e. ones that have been created in blockmesh or are created upon splitting a mesh for multi-region. This code would be included in the solver, not in controlDict.
If you wanted to do a loop over all faces in a domain, there are examples of this in the grad calc function in OpenFoam's source guide. I do have code for this and will try to post a "how" later on today.
Cheers,
DH
will_ca September 19, 2014 05:20
surface area of boundary
I solved my problem below. It is working.
I am using the coldEngine solver and I wanted to get the area of the cylinderwalls. The walls of the cylinder are definded as walls in a boundary patch called 'liner'. The mesh is changing over time and so is the surface of the liner.
This is the code I used:
#include "fvCFD.H"
#include "fvCFD.H"
#include "wallFvPatch.H"
// Main program:
int main(int argc, char *argv[])
timeSelector::addOptions();
#include "addRegionOption.H"
#include "setRootCase.H"
#include "createTime.H"
instantList timeDirs = timeSelector::select0(runTime, args);
#include "createNamedMesh.H"
forAll(timeDirs, timeI)
runTime.setTime(timeDirs[timeI], timeI);
Info<< "Time = " << runTime.timeName() << endl;
mesh.readUpdate();
label patchID = mesh.boundaryMesh().findPatchID("liner");
Info<<"\nsurface of liner "
<< gSum(mesh.magSf().boundaryField()[patchID])
<< endl;
Info<< "\nEnd\n" << endl;
return 0;
my problem now is that the results are wrong. They are much smaller than if I calculate the surface myself. I have checked everything I could think of, but haven't found the problem. I have checked the dimension of my cylinder in paraView and there the geometry is correct.
Does anyone know what the problem could be?
I would appreciate any help.
Ca
JasonWang3 September 23, 2015 05:25
Hi Will
Do you know how to access all faces that are parallel to a wall?
I am using the code: label cellI = patch.faceCells()[faceI]; to access the cells next to a wall.
Jason
tjliang August 24, 2016 07:52
Cheers
DH
Hello David,
do you know how to access patch field value for example temperature?
Thanks in advance,
Peng
