Moving Mesh on 3D Airfoil NACA 4412
Old   December 21, 2007, 11:33
Default Hi, i'm trying to simulate an
Emanuele
nuovodna is on a distinguished road
Hi, i'm trying to simulate an external flow on a NACA 4412 airfoil. i have a static 3D mesh (produced on Gambit) and i obtain good results on lift and drag coefficent. Now i want to simulate the flow during the airfoil rotation (like a wind turbine).
Thanks for advice
regards Emanuele
nuovodna is offline   Reply With Quote
Old   December 21, 2007, 12:01
Default Interesting, so you don't have
Frank Bos
lr103476 is on a distinguished road
Interesting, so you don't have any questions.....
Regards, Frank
Frank Bos
lr103476 is offline   Reply With Quote
Old   December 21, 2007, 12:02
Default I'd like to transform the case
Emanuele
I'd like to transform the case of the static airfoil to a case in which the airfoil rotates.
Regards
Emanuele
Old   December 27, 2007, 09:38
Default in what way i can impose a rot
Emanuele
in what way i can impose a rotating wall around the wing? or can the wing wall rotates in the space?
Thanks for advice
Emanuele
Old   December 27, 2007, 16:48
Default Hi Emanuele, Look at the MRFS
dmoroian's Avatar
Dragos
dmoroian is on a distinguished road
Hi Emanuele,
Look at the MRFSimpleFoam.
Dragos
dmoroian is offline   Reply With Quote
Old   January 2, 2008, 16:20
Default hi dragos i don't understand
Emanuele
hi dragos
i don't understand in what way i can set a rotatory condition on my wing...can you post me an exemple?
Thanks for advice
Emanuele
Old   January 3, 2008, 11:03
Default Hi Emanuele, I hope I didn't
dmoroian's Avatar
Dragos
Hi Emanuele,
I hope I didn't understand your post wrong, but if you try to compute a rotating body, like a "wind turbine" then MRFSimpleFoam solver (and the tutorial) is what you need.
If you need help with that, I will try to provide it.
Dragos
[Commercial meshers] Naca 0012 airfoil naveen OpenFOAM Meshing & Mesh Conversion 7 April 14, 2011 11:03
Solving NACA AIRFOIL naveen OpenFOAM Running, Solving & CFD 1 February 6, 2009 06:43
Naca Airfoil Dario Main CFD Forum 5 July 13, 2007 19:23
meshing a Naca 4412 airfoil - help Santiago Orrego. CFX 3 December 18, 2006 04:42
Naca airfoil with to much drag Andreas CFX 6 March 17, 2006 06:13
