Error during Foam simulation
Old   December 19, 2007, 10:46
Default Dears, I've a problem with Fo
Stefano Dalla Costa
stefano is on a distinguished road
Dears,
I've a problem with Foam simulation. I've defined a 3d domain (simple cylinder with inlet, outlet and wall) using Salome and then I've correctly imported the .unv file in Foam. When I launch a simulation using "simpleFoam" the results are the following messages:
DILUPBiCG: Solving for Ux, Initial residual = 1, Final residual = 0.0142031, No Iterations 2
DILUPBiCG: Solving for Uy, Initial residual = 1, Final residual = 0.0570803, No Iterations 1
DILUPBiCG: Solving for Uz, Initial residual = 1, Final residual = 0.0482498, No Iterations 1
DICPCG: Solving for p, Initial residual = 1, Final residual = 0.008993, No Iterations 18
time step continuity errors : sum local = 0.492712, global = -0.0016149, cumulative = -0.0016149
#0 Foam::error::printStack(Foam:stream&) in "/home/matteo/OpenFOAM/OpenFOAM-1.4.1/lib/linuxGccDPOpt/libOpenFOAM.so"
#1 Foam::sigFpe::sigFpeHandler(int) in "/home/matteo/OpenFOAM/OpenFOAM-1.4.1/lib/linuxGccDPOpt/libOpenFOAM.so"
#2 Uninterpreted: [0xffffe420]
#3 Foam::divide(Foam::Field<double>&, Foam::UList<double> const&, Foam::UList<double> const&) in "/home/matteo/OpenFOAM/OpenFOAM-1.4.1/lib/linuxGccDPOpt/libOpenFOAM.so"
#4 void Foam::divide<foam::fvpatchfield,>(Foam::GeometricF ield<double,>&, Foam::GeometricField<double,> const&, Foam::GeometricField<double,> const&) in "/home/matteo/OpenFOAM/OpenFOAM-1.4.1/lib/linuxGccDPOpt/libincompressibleTurbule nceModels.so"
#5 Foam::tmp<foam::geometricfield<double,> > Foam::operator/<foam::fvpatchfield,>(Foam::tmp<foam::geometricfie ld<double,> > const&, Foam::GeometricField<double,> const&) in "/home/matteo/OpenFOAM/OpenFOAM-1.4.1/lib/linuxGccDPOpt/libincompressibleTurbule nceModels.so"
#6 Foam::turbulenceModels::kEpsilon::correct() in "/home/matteo/OpenFOAM/OpenFOAM-1.4.1/lib/linuxGccDPOpt/libincompressibleTurbule nceModels.so"
#7 main in "/home/matteo/OpenFOAM/OpenFOAM-1.4.1/applications/bin/linuxGccDPOpt/simpleFoam"
#8 __libc_start_main in "/lib/tls/i686/cmov/libc.so.6"
#9 Foam::regIOobject::readIfModified() in "/home/matteo/OpenFOAM/OpenFOAM-1.4.1/applications/bin/linuxGccDPOpt/simpleFoam"
Floating point exception (core dumped)
Is there someone that could help me?
Thanks
Stefano.
stefano is offline   Reply With Quote
Old   December 19, 2007, 10:54
Default I bet you initialised k or eps
Hrvoje Jasak
I bet you initialised k or epsilon to zero, probably in the internal field: check your files 0/k and 0/epsilon.
If so, pick your own punishment
Hrv
Hrvoje Jasak
Old   December 19, 2007, 11:13
Default Thanks While I'm punishing m
Stefano Dalla Costa
Thanks
While I'm punishing myself, could you to explain me something about this initialization values?
Stefano.
Old   December 19, 2007, 14:35
Default Yes, have a look at the k-epsi
Hrvoje Jasak
Yes, have a look at the k-epsilon equations:
mu_t = C_mu sqt(k)/epsilon
and the source terms in epsilon eqn (for example)
C1 G epsilon/k and
C2 sqr(epsilon)/k
Thus, while
k = epsilon = 0
formally satisfies the equation set, you will get floating point exception: division by zero.
Got it?
Hrv
Hrvoje Jasak
Old   December 20, 2007, 03:11
Default Yes, thanks. If we consider
Stefano Dalla Costa
Yes, thanks.
If we consider two different variables, i.e. turbulence intensity I and turbulent viscosity ratio Rv = mu(t) / mu where:
I = u' / u(avg) = 0.16 * Re(Dh)^-1/8;
Rv = [1, 10];
it is correct to assume:
k = (3 / 2) * (u(avg) * I)^2;
eps = rho * C(mu) * (k^2 / mu) * Rv^-1;
C(mu) = 0.09 (only for k-eps model)
Ste.
Compiling MRFSimple foam error mrangitschdowcom OpenFOAM Installation 0 September 15, 2008 15:09
FOAM FATAL IO ERROR msrinath80 OpenFOAM Running, Solving & CFD 4 July 30, 2008 10:06
FOAM FATAL ERROR derath OpenFOAM Pre-Processing 1 June 10, 2006 14:20
FOAM installation error gcc amp g hanks OpenFOAM Installation 9 January 26, 2006 14:14
FOAM FATAL IO ERROR sita OpenFOAM Running, Solving & CFD 2 August 23, 2005 04:37
