Home > Forums > OpenFOAM Running, Solving & CFD
Symmetrical Model With Non Symmetrical Solution
Old   November 7, 2007, 08:07
Default Dragos, you were totally righ
  #21
Luca Liberti
fugu is on a distinguished road
Dragos,
you were totally right: the flow past a sudden expansion is inherently unstable and asymmetrical
when Re exceeds a critical value. Even the RANS mean flow shows asymmetrical features at least for averaging times used in literature.
See De Zilwa et al. "Flows through plane sudden-expansion" Int. J. for numerical methods in Fluids 2000 32 313-329
As for Jason problem, I guess might help to make the geometry of the join between the main pipe and the smaller ones as gradual and smooth as possible maybe reducing its angle.
Hope it helps
Luca
fugu is offline   Reply With Quote
Old   November 7, 2007, 11:57
Default Hi Luca, Thank you very much
  #22
dmoroian's Avatar
Dragos
dmoroian is on a distinguished road
Hi Luca,
Thank you very much for the references, I'll try to get them.
Jason, as I remember, the asymmetry appears only for certain ratios between the inlet diameter and expansion diameter. In my oppinion, one of the solutions (besides that suggested already by Luca), you should increase this ratio (decrease the inlet diameter or increase the expansion diameter). It sould be easy to see that with the simple example from above. Just play with the diameters until you get the symmetric solution.
dmoroian is offline   Reply With Quote
Old   November 8, 2007, 07:05
Default Hi, Thank you for your comm
  #23
Jason Dale
jason is on a distinguished road
Thank you for your comments and help. I don't want to take up any more of your time so I will carry on looking into this further and let you know if I manage to solve it.
Kind Regards
Jason
jason is offline   Reply With Quote
Old   December 10, 2007, 05:19
Default Hello all would you please
  #24
Armin Hosseinian
armin_h is on a distinguished road
Hello all
would you please any one let me know how can i push flow into the pipe in openfoam?
I have created the geometry of the pipe and also the mesh.
I need to see the velocity profile which comes from the moving flow into the pipe.
I am new user of openfoam and i dont know how can i put the amounts for the u velocity and see the motion of the fluid inside the pipe.
I would appreciate any comments.
sorry if it is not an advance question.
Cheers
Armin
armin_h is offline   Reply With Quote
Old   December 10, 2007, 07:21
Default Hello Armin, I think it would
  #25
dmoroian's Avatar
Dragos
Hello Armin,
I think it would be helpfulf for you if you download the case files mentioned above ( POST17811), and start from there.
Dragos
Old   December 18, 2007, 03:49
Default Dear Dragos Appreciate abot
  #26
Armin Hosseinian
Dear Dragos
Appreciate abot the answer.
I will work for it.
SOrry i bother you.
Many Thanks again.
Kinds Regards
Armin Hosseinian
Thread Tools
Trackbacks are On
Forces on symmetrical bodies Virag CFX 2 July 8, 2007 13:50
Simulation of symmetrical parts Amer FLUENT 0 May 8, 2007 02:59
periodic & symmetrical BC justin Main CFD Forum 0 January 17, 2007 13:36
symmetry is not symmetrical! Dave FLUENT 2 April 2, 2004 06:55
Non-symmetrical Martin FLUENT 4 June 18, 2001 10:12
