parallelised OpenFoam solver on diverges earlier when the number of cores are higher
Old   August 24, 2018, 09:43
Default parallelised OpenFoam solver on diverges earlier when the number of cores are higher
Foad
foadsf is on a distinguished road
Hi foamers,
I have a model which I'm trying to solve on a cluster (zip file in the attachment). When I divide the problem into 7 segments it solves till 6.74 but when I have 50 segments it stops at 0.72! In fact this is quite random. but in general the higher the number of cores the faster by average it will stop.
I run the problem with:
blockmesh
decomposePar
srun -N 1 --ntasks-per-node=7 --pty bash
mpirun -np 7 sonicFoam -parallel -fileHandler uncollated > log.log 2>&1
reconstructPar
and these are a sample of errors I get:
[21] --> FOAM FATAL ERROR:
[21] Maximum number of iterations exceeded: 100
[21]
[21]     From function Foam::scalar Foam::species::thermo<Thermo, Type>::T(Foam::scalar, Foam::scalar, Foam::scalar, Foam::scalar (Foam::species::thermo<Thermo, Type>::*)(Foam::scalar, Foam::scalar) const, Foam::scalar (Foam::species::thermo<Thermo, Type>::*)(Foam::scalar, Foam::scalar) const, Foam::scalar (Foam::species::thermo<Thermo, Type>::*)(Foam::scalar) const) const [with Thermo = Foam::hConstThermo<Foam::perfectGas<Foam::specie> >; Type = Foam::sensibleInternalEnergy; Foam::scalar = double; Foam::species::thermo<Thermo, Type> = Foam::species::thermo<Foam::hConstThermo<Foam::perfectGas<Foam::specie> >, Foam::sensibleInternalEnergy>]
[21]     in file /home/foobar/OpenFOAM/OpenFOAM-v1712/src/thermophysicalModels/specie/lnInclude/thermoI.H at line 73.
[21]
FOAM parallel run aborting
continued with:
[21] #5  ? at ??:?
[30] #5  ? at ??:?
[28] #5   at ??:?
[49] #4  Foam::hePsiThermo<Foam::psiThermo, Foam::pureMixture<Foam::constTransport<Foam::species::thermo<Foam::hConstThermo<Foam::perfectGas<Foam::specie> >, Foam::sensibleInternalEnergy> > > >::correct()? at ??:?
[5] #5   at ??:?
[36] #5  ?? at ??:?
[43] #5   at ??:?
[32] #6  __libc_start_main at ??:?
[45] #4   at ??:?
[44] #5  ? at ??:?
[35] #5   at ??:?
[40] #5   at ??:?
[47] #5   at ??:?
[27] #5   at ??:?
[31] #5   at ??:?
[38] #6  __libc_start_main? at ??:?
[11] #5   at ??:?
[41] #5   at ??:?
[25] #5   at ??:?
[42] #6   at ??:?
[34] #6  __libc_start_main__libc_start_main? at ??:?
[24] #5   at ??:?
[9] #5   at ??:?
[1] #5   at ??:?
[48] #5   in "/lib/x86_64-linux-gnu/libc.so.6"
[3] #7   at ??:?
[29] #5   at ??:?
[10] #5   at ??:?
[26] #6  __libc_start_main at ??:?
[23] #6  __libc_start_main? at ??:?
[33] #5  ?? at ??:?
[4] #5  ?? in "/lib/x86_64-linux-gnu/libc.so.6"
[32] #7  ??? at ??:?
[39] #5  ? at ??:?
[30] #6  __libc_start_main? at ??:?
[46] #5  ? in "/lib/x86_64-linux-gnu/libc.so.6"
[38] #7  ? at ??:?
[37] #6  __libc_start_main in "/lib/x86_64-linux-gnu/libc.so.6"
[42] #7  ? at ??:?
[28] #6  __libc_start_main? in "/lib/x86_64-linux-gnu/libc.so.6"
[26] #7  ?? in "/lib/x86_64-linux-gnu/libc.so.6"
?[34] #7   at ??:?
[21] #6  __libc_start_main????? at ??:?
[43] #6  __libc_start_main? in "/lib/x86_64-linux-gnu/libc.so.6"
[23] #7   at ??:?
[5] #6  __libc_start_main at ??:?
[47] #6  __libc_start_main at ??:?
[44] #6  __libc_start_main at ??:?
[35] #6  __libc_start_main at ??:?
[45] #5  __libc_start_main at ??:?
[27] #6  __libc_start_main in "/lib/x86_64-linux-gnu/li?bc.so.6"
[30] #7  ?? in "/lib/x86_64-linux-gnu/libc.so.6"
[37] #7   at ??:?
[49] #5  ?? at ??:?
[28] #7   at ??:?
[24] #6  __libc_start_main--------------------------------------------------------------------------
MPI_ABORT was invoked on rank 3 in communicator MPI_COMM_WORLD
with errorcode 1.
NOTE: invoking MPI_ABORT causes Open MPI to kill all MPI processes.
You may or may not see output from other processes, depending on
exactly when Open MPI kills them.
 at ??:?
[36] #6  __libc_start_main at ??:?
[1] #6  __libc_start_main at ??:?
[40] #6  __libc_start_main? at ??:?
 at ??:?
[33] #6  __libc_start_main[10] #6  __libc_start_main at ??:?
[31] #6  __libc_start_main at ??:?
[48] #6  __libc_start_main at ??:?
[29] #6  __libc_start_main at ??:?
[9] #6  __libc_start_main in "/lib/x86_64-linux-gnu/libc.so.6"
[27] #7  [43] #7   at ??:?
[39] #6  __libc_start_main in "/lib/x86_64-linux-gnu/libc.so.6"
[5] #7   at ??:?
[25] #6  __libc_start_main at ??:?
[4] #6   at ??:?
[41] #6  __libc_start_main__libc_start_main in "/lib/x86_64-linux-gnu/libc.so.6"
[47] #7  ?? at ??:?
 at ??:?
[11] #6  __libc_start_main in "/lib/x86_64-linux-gnu/libc.so.6"
[44] #7   at ??:?
[35] #7   at ??:?
?? at ??:?
[weleveld:20500] 3 more processes have sent help message help-mpi-api.txt / mpi-abort
[weleveld:20500] Set MCA parameter "orte_base_help_aggregate" to 0 to see all help / error messages
The complete error message can be found in the attachments. (divided into 3 files, download all and remove the .txt at the end and unzip)
I would appreciate if you could let me know what is the problem and how I can solve it.
foadsf is offline   Reply With Quote
Old   August 29, 2018, 13:12
Michael Alletto
mAlletto will become famous soon enough
I think this is not unusual since with increasing number of processors the solution becomes more and more decoupled
mAlletto is offline   Reply With Quote
Old   August 29, 2018, 18:17
Foad
So what is the best solution?
Old   September 5, 2018, 02:53
TWB
quarkz is on a distinguished road
Hi, I have a similar problem but opposite of yours - Running at 288 cores, it diverges but at 600 cores, I got a converged solution:
Problem diverges or not depending on procs number
quarkz is offline   Reply With Quote
diverge, mpi, openfoam, slurm, sonicfoam
LES, Courant Number, Crash, Sudden Alhasan OpenFOAM Running, Solving & CFD 5 November 22, 2019 02:05
Star cd es-ice solver error ernarasimman STAR-CD 2 September 12, 2014 00:01
Cluster ID's not contiguous in compute-nodes domain. ??? Shogan FLUENT 1 May 28, 2014 15:03
DecomposePar unequal number of shared faces maka OpenFOAM Pre-Processing 6 August 12, 2010 09:01
Unaligned accesses on IA64 andre OpenFOAM 5 June 23, 2008 10:37
