Home > Forums > OpenFOAM Running, Solving & CFD
Vibrating Airfoil Analyses
Old   November 26, 2007, 07:29
Default Dear Forum, I forgot to ask
Alessandro Spadoni
gtg627e is on a distinguished road
Dear Forum,
I forgot to ask about z-dimension in LES:
What would be the extent of the z-dimension for the airfoil model described above?
How many cells would you recommend in the z-direction?
Thank you,
Alessandro Spadoni
gtg627e is offline   Reply With Quote
Old   December 1, 2007, 22:21
Default Dear Forum, I have produced
Alessandro Spadoni
Dear Forum,
I have produced a new mesh whereby the inlet region touches the outlet region, similarly to the tutorial sonicTurbFoam/nacaairfoil.
I was wondering if it is ok to have my inlet touch the outlet. If this is ok, what are the approriate boundary conditions to facilitate convergence?
At the moment, I use
inlet:
U fixed value
p zeroGradient
otlet:
U zeroGradient
p fixedvalue 0
Would it be better to use inletOutlet?
or alternaltively, set p zeroGradient at the outlet?
Thank you,
Alessandro
Old   December 4, 2007, 13:36
Default Dear Forum, Forgive me if I
Alessandro Spadoni
Dear Forum,
Forgive me if I ask some questions that may be answered by looking at references. I am really trying to get a grasp of how turbulence modeling is done in OpenFOAM, and I am having some problems.
I am struggling with getting convergence with fine grids. By fine I mean Fluent converges and tells me that the resulting y+ ~ 1 (used k-w SST with transient flow option turned on, meaning low Re version).
As posted in
http://www.cfd-online.com/OpenFOAM_D...tml?1196717652
I get good convergence using the kOmegaSST model with a y+ of about 7 in OpenFOAM. I now refined the grid to prepare good initial conditions for a LES case, and I get very poor or no convergence.
This is the initial residual for pressure:
I understand the implementation of kOmegaSST in OpenFOAM always uses wall functions (do I undestand this correctly?), and thus the boundary file should have:
myWallPatch
type wall;
physicalType wallFunctions;
What happens if I do not declare physicalType?
Does the model still uses wallFunctions by default?
Is there an a lowRe k-w SST model in OpenFOAM?
If I were to use one of the low Re models supplied with OpenFOAM, say LRR, how would I define by wall patches?
myWallPatch
type pach;
would this be correct?
I did search through the postings, but I could not find any information about the boundary file specifications for low Re models, and most questions about wallFunctions refer to the k-e model.
Thank you for your help,
Alessandro
Old   December 4, 2007, 13:39
Default Dear Forum, The jump in ini
Alessandro Spadoni
Dear Forum,
The jump in initial pressure residual at about iteration number 1000 happened spontaneously. I did not change fvSchemes or anything else.
Thank you,
alessandro
Thread Tools
Trackbacks are On
Force values in time-dependant analyses Zmur Main CFD Forum 0 July 11, 2008 04:50
cfdesign and pump analyses kaan Autodesk Simulation CFD 0 August 6, 2007 15:02
FSI analysis-time steps for transient analyses seb CFX 0 June 9, 2005 07:17
Use of Scaling in numerical Analyses? Melanie Mills Main CFD Forum 2 July 25, 1999 22:33
Basic CFD analyses of radomes Brian MacKay Main CFD Forum 8 March 10, 1999 23:53
