My blockmeshdict is :
/*---------------------------------------------------------------------------*\ | ========= | | | \ / F ield | OpenFOAM: The Open Source CFD Toolbox | | \ / O peration | Version: 1.3 | | \ / A nd | Web: http://www.openfoam.org | | \/ M anipulation | | \*---------------------------------------------------------------------------*/ FoamFile { version 2.0; format ascii; root ""; case ""; instance ""; local ""; class dictionary; object blockMeshDict; } // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // convertToMeters 1; vertices ( (-0.5 0.33377906 0.01457311) (-0.45 0.31030427 0.01354818) (-0.4 0.28768137 0.01256044) (-0.35 0.26612769 0.01161939) (-0.3 0.24592454 0.0107373) (-0.25 0.22743209 0.0099299) (-0.2 0.21110041 0.00921684) (-0.15 0.19746635 0.00862157) (-0.1 0.18712052 0.00816986) (-0.05 0.1806288 0.00788642) (0 0.17841241 0.00778965) (0.05 0.1806288 0.00788642) (0.1 0.18712052 0.00816986) (0.15 0.19746635 0.00862157) (0.2 0.21110041 0.00921684) (0.25 0.22743209 0.0099299) (0.3 0.24592454 0.0107373) (0.35 0.26612769 0.01161939) (0.4 0.28768137 0.01256044) (0.45 0.31030427 0.01354818) (0.5 0.33377906 0.01457311) (-0.5 0.33377906 -0.01457311) (-0.45 0.31030427 -0.01354818) (-0.4 0.28768137 -0.01256044) (-0.35 0.26612769 -0.01161939) (-0.3 0.24592454 -0.0107373) (-0.25 0.22743209 -0.0099299) (-0.2 0.21110041 -0.00921684) (-0.15 0.19746635 -0.00862157) (-0.1 0.18712052 -0.00816986) (-0.05 0.1806288 -0.00788642) (0 0.17841241 -0.00778965) (0.05 0.1806288 -0.00788642) (0.1 0.18712052 -0.00816986) (0.15 0.19746635 -0.00862157) (0.2 0.21110041 -0.00921684) (0.25 0.22743209 -0.0099299) (0.3 0.24592454 -0.0107373) (0.35 0.26612769 -0.01161939) (0.4 0.28768137 -0.01256044) (0.45 0.31030427 -0.01354818) (0.5 0.33377906 -0.01457311) ( -0.5 0 0) (-0.45 0 0) (-0.4 0 0) (-0.35 0 0) (-0.3 0 0) (-0.25 0 0) (-0.2 0 0) (-0.15 0 0) (-0.1 0 0) (-0.05 0 0) (0 0 0) (0.05 0 0) (0.1 0 0) (0.15 0 0) (0.2 0 0) (0.25 0 0) (0.3 0 0) (0.35 0 0) (0.4 0 0) (0.45 0 0) (0.5 0 0) ); blocks ( hex (42 43 22 21 42 43 1 0) (5 20 1) simpleGrading (1 1 1) hex (43 44 23 22 43 44 2 1) (5 20 1) simpleGrading (1 1 1) hex (44 45 24 23 44 45 3 2) (5 20 1) simpleGrading (1 1 1) hex (45 46 25 24 45 46 4 3) (5 20 1) simpleGrading (1 1 1) hex (46 47 26 25 46 47 5 4) (5 20 1) simpleGrading (1 1 1) hex (47 48 27 26 47 48 6 5) (5 20 1) simpleGrading (1 1 1) hex (48 49 28 27 48 49 7 6) (5 20 1) simpleGrading (1 1 1) hex (49 50 29 28 49 50 8 7) (5 20 1) simpleGrading (1 1 1) hex (50 51 30 29 50 51 9 8) (5 20 1) simpleGrading (1 1 1) hex (51 52 31 30 51 52 10 9) (5 20 1) simpleGrading (1 1 1) hex (52 53 32 31 52 53 11 10) (5 20 1) simpleGrading (1 1 1) hex (53 54 33 32 53 54 12 11) (5 20 1) simpleGrading (1 1 1) hex (54 55 34 33 54 55 13 12) (5 20 1) simpleGrading (1 1 1) hex (55 56 35 34 55 56 14 13) (5 20 1) simpleGrading (1 1 1) hex (56 57 36 35 56 57 15 14) (5 20 1) simpleGrading (1 1 1) hex (57 58 37 36 57 58 16 15) (5 20 1) simpleGrading (1 1 1) hex (58 59 38 37 58 59 17 16) (5 20 1) simpleGrading (1 1 1) hex (59 60 39 38 59 60 18 17) (5 20 1) simpleGrading (1 1 1) hex (60 61 40 39 60 61 19 18) (5 20 1) simpleGrading (1 1 1) hex (61 62 41 40 61 62 20 19) (5 20 1) simpleGrading (1 1 1) ); edges ( ); patches ( patch inlet ( (42 42 0 21) ) patch outlet ( (62 62 41 20) ) wall wall ( (0 1 22 21) (1 2 23 22) (2 3 24 23) (3 4 25 24) (4 5 26 25) (5 6 27 26) (6 7 28 27) (7 8 29 28) (8 9 30 29) (9 10 31 30) (10 11 32 31) (11 12 33 32) (12 13 34 33) (13 14 35 34) (14 15 36 35) (15 16 37 36) (16 17 38 37) (17 18 39 38) (18 19 40 39) (19 20 41 40) ) wedge front ( (42 43 1 0) (43 44 2 1) (44 45 3 2) (45 46 4 3) (46 47 5 4) (47 48 6 5) (48 49 7 6) (49 50 8 7) (50 51 9 8) (51 52 10 9) (52 53 11 10) (53 54 12 11) (54 55 13 12) (55 56 14 13) (56 57 15 14) (57 58 16 15) (58 59 17 16) (59 60 18 17) (60 61 19 18) (61 62 20 19) ) wedge back ( (21 22 43 42) (22 23 44 43) (23 24 45 44) (24 25 46 45) (25 26 47 46) (26 27 48 47) (27 28 49 48) (28 29 50 49) (29 30 51 50) (30 31 52 51) (31 32 53 52) (32 33 54 53) (33 34 55 54) (34 35 56 55) (35 36 57 56) (36 37 58 57) (37 38 59 58) (38 39 60 59) (39 40 61 60) (40 41 62 61) ) empty axis ( (42 43 43 42) (43 44 44 43) (44 45 45 44) (45 46 46 45) (46 47 47 46) (47 48 48 47) (48 49 49 48) (49 50 50 49) (50 51 51 50) (51 52 52 51) (52 53 53 52) (53 54 54 53) (54 55 55 54) (55 56 56 55) (56 57 57 56) (57 58 58 57) (58 59 59 58) (59 60 60 59) (60 61 61 60) (61 62 62 61) ) ); mergePatchPairs ( ); // ************************************************** *********************** // this is a 2d axis-symmetry nozzle . The solver is rhoSonicFoam ,when I run the case this error appears: Root : /home/msha/OpenFOAM/msha-1.3/run/tutorials/rhoSonicFoam Case : nozzle Nprocs : 1 Create time Create mesh for time = 0 Reading thermodynamicProperties Reading field p Reading field T Reading field U Starting time loop Time = 1e-05 Lookup interpolationScheme for interpolate(rho) Lookup interpolationScheme for interpolate(rhoU) Max Courant Number = 0.120569 Lookup divScheme for div(phiv,rho) Lookup gradScheme for grad(rho) --> FOAM FATAL ERROR : request for surfaceScalarField phi from objectRegistry region0 failed available objects of type surfaceScalarField are 4 ( weightingFactors limiter differenceFactors_ phiv ) From function objectRegistry::lookupObject<type>(const word&) const in file /home/dm2/henry/OpenFOAM/OpenFOAM-1.3/src/OpenFOAM/lnInclude/objectRegistryTempl ates.C at line 122. FOAM aborting Foam::error::printStack(Foam:http://www.cfd-online.com/OpenFOAM_D...part/proud.gifstream&) Foam::error::abort() Foam::GeometricField<double,> const& Foam::objectRegistry::lookupObject<foam::geometric field<double,> >(Foam::word const&) const Foam::totalPressureFvPatchScalarField::updateCoeff s() Foam::GeometricField<double,>::GeometricBoundaryFi eld::updateCoeffs() Foam::fvMatrix<double>::fvMatrix(Foam::GeometricFi eld<double,>&, Foam::dimensionSet const&) Foam::fv::gaussConvectionScheme<double>::fvmDiv(Fo am::GeometricField<double,> const&, Foam::GeometricField<double,>&) const Foam::tmp<foam::fvmatrix<double> > Foam::fvm::div<double>(Foam::GeometricField<double ,> const&, Foam::GeometricField<double,>&, Foam::word const&) Foam::tmp<foam::fvmatrix<double> > Foam::fvm::div<double>(Foam::GeometricField<double ,> const&, Foam::GeometricField<double,>&) rhoSonicFoam [0x8059060] __libc_start_main __gxx_personality_v0 Aborted what can I do? |
Isn't any one for help in this
Isn't any one for help in this subject
Please help any way. THANK YOU ALL MSHA |
I have encountered the same pr
I have encountered the same problem of
--> FOAM FATAL ERROR : request for surfaceScalarField phi from objectRegistry region0 failed available objects of type surfaceScalarField are 4 ( weightingFactors differenceFactors_ phiv vanLeerLimiter(rhoU) ) for a 2d flow over an afoil with rhoSonicFoam Can some one point out my mistakes ...? Regards, |
I know this thread is old, but I'm encountering the same problem with OpenFoam Version 1.6. It's the rhoSonicFoam as well and it happens when calling
fvm::div(phiv, rho); The error message is the same, I'll post it anyway: request for surfaceScalarField phi from objectRegistry region0 failed available objects of type surfaceScalarField are 4 ( phiv limitedLinearLimiter(rho) differenceFactors_ weightingFactors ) I looked through all my files. There is never a phi used, only phiv. It still works well on the shockTube tutorial, but not on my case and I don't know, what I'm doing wrong. |
Although this thread may seem a little bit old I think it might help if I share my thoughts on this. I found an error in my BC when using waveTransmissive, which uses the field phi, whereas rhoSonicFoam uses phiv.
A simple workaround was for me to simply recompile the solver for using phi (changing every phiv to phi). It might be possible to change waveTransmissive to use phiv, but I didn't try that. |
LaplacianFoam
As none of the members above could get an answer and as I am pretty much in the same situation, I'm digging out (don't know if it's valuable in English ^^) this thread.
I have trouble with a laplacianFoam simulation where I got this Error message when running: Code:
--> FOAM FATAL ERROR: Thank you for your time :) [Edit]: I already tried to replace in fvSchemes "phi" by "DT" (DT defined in transportProperties) but still |
Three year old thread but hey, it doesn't hurt to post a fix, right?
Create a phi initial and boundary conditions file in folder 0/ and you're set. I haven't figured out why bubbleFoam doesn't create phi automatically as it is supposed to and does in most cases but if you create the file for it everything runs smoothly. |
I have encountered the same problem, but no posted advice works
I got a similar problem when trying to run potentialFoam. I have tried to apply Ziad suggestion by creating phi initial and boundary conditions file in folder 0/. However, it doesn't work and the terminal window displays the following: --> FOAM FATAL ERROR: request for surfaceScalarField phiHbyA from objectRegistry region0 failed available objects of type surfaceScalarField are 3 ( (1*magSf) phi 1 ) From function objectRegistry::lookupObject<Type>(const word&) const in file /home/opencfd/OpenFOAM/OpenFOAM-2.2.2/src/OpenFOAM/lnInclude/objectRegistryTemplates.C at line 164. FOAM aborting #0 Foam::error::printStack(Foam::Ostream&) in "/opt/openfoam222/platforms/linuxGccDPOpt/lib/libOpenFOAM.so" #1 Foam::error::abort() in "/opt/openfoam222/platforms/linuxGccDPOpt/lib/libOpenFOAM.so" #2 Foam::GeometricField<double, Foam::fvsPatchField, Foam::surfaceMesh> const& Foam::objectRegistry::lookupObject<Foam::Geometric Field<double, Foam::fvsPatchField, Foam::surfaceMesh> >(Foam::word const&) const in "/opt/openfoam222/platforms/linuxGccDPOpt/lib/libfiniteVolume.so" #3 Foam::fixedFluxPressureFvPatchScalarField::updateC oeffs() in "/opt/openfoam222/platforms/linuxGccDPOpt/lib/libfiniteVolume.so" #4 at gaussLaplacianSchemes.C:0 #5 Foam::fv::gaussLaplacianScheme<double, double>::fvmLaplacianUncorrected(Foam::GeometricFi eld<double, Foam::fvsPatchField, Foam::surfaceMesh> const&, Foam::GeometricField<double, Foam::fvsPatchField, Foam::surfaceMesh> const&, Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh> const&) in "/opt/openfoam222/platforms/linuxGccDPOpt/lib/libfiniteVolume.so" #6 Foam::fv::gaussLaplacianScheme<double, double>::fvmLaplacian(Foam::GeometricField<double, Foam::fvsPatchField, Foam::surfaceMesh> const&, Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh> const&) in "/opt/openfoam222/platforms/linuxGccDPOpt/lib/libfiniteVolume.so" #7 in "/opt/openfoam222/platforms/linuxGccDPOpt/bin/potentialFoam" #8 in "/opt/openfoam222/platforms/linuxGccDPOpt/bin/potentialFoam" #9 in "/opt/openfoam222/platforms/linuxGccDPOpt/bin/potentialFoam" #10 __libc_start_main in "/lib/i386-linux-gnu/libc.so.6" #11 in "/opt/openfoam222/platforms/linuxGccDPOpt/bin/potentialFoam" Aborted (core dumped) As in my case the error message says "phiHbyA" rather than "phi", I also made a file for "phiHbyA" in 0/ folder. But it still can't work and the error message I receive is always the same. Any idea on how to fix this? I'll appreciate that so much. Cheers |
solution
In case of airfoil, rhoSonicFoam doesn't support BC such as waveTransmissive. It includes manipulation with phi field.
Good luck. |
#include "createPhia.H" |
I have openfoam 2.1.x installed on windows. My cases with single domains are running fine but when I run some case with multiple domains (e.g. conjugate heat transfer cases) I get the following error.
--> FOAM FATAL ERROR: |
