Home > Forums > OpenFOAM Running, Solving & CFD
VOF interface
Old   June 1, 2005, 06:46
Default Aah, my mistake. I was wonderi
  #21
Eugene de Villiers
eugene is on a distinguished road
Aah, my mistake. I was wondering where g was hiding.
Still, the pressure does behave strangely toward the bottom of the outlet and the removal of gravity makes the problem as described above go away. I will have another look at the formulation when I have some time.
eugene is offline   Reply With Quote
Old   June 1, 2005, 06:55
Default Belay that, after a second loo
  #22
Eugene de Villiers
Belay that, after a second look I dont believe there is anything wrong at or near the outlet.
Old   June 1, 2005, 07:07
Default Dear Mattijs, thanks for the
  #23
Rattin Michele
michele is on a distinguished road
Dear Mattijs,
thanks for the help. I tried to compile the new zipUpMesh, but I experienced problems (the compilation of the old zipUpMesh executable was instead straightforward).
I obtained the following errors after issuing wmake:
Making dependency list for source file zipUpCells.C
Making dependency list for source file zipUpMesh.C
SOURCE_DIR=.
SOURCE=zipUpCells.C ; g++ -m64 -DlinuxAMD64 -Wall -W -Wno-unused-parameter -march=opteron -O3 -ffast-math -fno-gcse -DNoRepository -ftemplate-depth-30 -I/home/michele/OpenFOAM/OpenFOAM-1.1/src/OpenFOAM/lnInclude -IlnInclude -I. -fPIC -c $SOURCE -o Make/linuxAMD64Opt/zipUpCells.o
zipUpCells.C: In member function `void Foam::polyMesh::zipUpCells()':
zipUpCells.C:134: error: `WarningIn' undeclared (first use this function)
zipUpCells.C:134: error: (Each undeclared identifier is reported only once for each function it appears in.)
make: *** [Make/linuxAMD64Opt/zipUpCells.o] Error 1
However, if you are interested on a test mesh, the following link is that of the case under discussion:
www.lem3.it/tests/waves_050601/waves.tar.gz
Michele.
PS. Henry, I've just started a simulation with low order approximations, walls whose condition was set to 2 m/s (in rasInterFoam is not coded the slipWall condition, am I right?), and compression coefficient for gamma of 1.0. I will obtain results in about 3 hours...
michele is offline   Reply With Quote
Old   June 1, 2005, 07:29
Default Hi Michele, Sorry, didn't t
  #24
Mattijs Janssens
mattijs is on a distinguished road
Hi Michele,
Sorry, didn't try it under 1.1.
Replace in zupUpCells.C
WarningIn("XXXX")
with
Warning<< "XXXX"
mattijs is offline   Reply With Quote
Old   June 1, 2005, 08:38
Default Hi Mattijs, thank you. Now
  #25
Rattin Michele
Hi Mattijs,
thank you.
Now the utility zipUpMesh works correctly. The corrected mesh passes all the tests of the checkMesh.
Thanks,
Michele.
Old   June 1, 2005, 09:10
Default Dear Henry: >> Why do you t
  #26
Rattin Michele
Dear Henry:
>> Why do you think there is a problem with the oulet pressure BC? Remember we are solving for pd which is p - rho*g*h, i.e. is constant with depth at the outlet.
Excuse me, Henry, isn't pd = p - g*h ?
I expect for pd the dimensions [m^2/s^2], am I correct?
Another question about the pressure. I'm interested in computing the pressure around floating bodies (and integrate pressure and viscous/turbulent stress over surfaces in order to obtain overall forces).
It is rather complicated to obtain pressure: if I use the expression p = pd + gh, h is not a constant as it depends on the wave elevation above each point.
That is to say that
p = pd + int(-gamma*g, ds)
an integral to be computed along the g direction (gamma is zero in air and one in water, introduced in order to capture the surface).
But below a floating body it is impossible to integrate up to a free surface (this space is occupied by the floating body itself!).
Have you any suggestion?
Ragarding the simulation, I'm making the run with the parameters you suggested.
However my impression is the following: it seems to me that boundary conditions don't pose any problem on the solution: all the instability grows well after the flow enters the domain. It resembles more a turbulence generated instability...
By the way, I would like to get the eddy viscosity among the output results... is it automatically possible or does this require coding?
Old   June 1, 2005, 09:49
Default > Excuse me, Henry, isn't pd =
  #27
henry is on a distinguished road
No pd = p - rho*(g.h) and you can calculate p from pd using this expression. Notice the dimension of pd:
dimensions [1 -1 -2 0 0 0 0];
h is the the position vectors of the cell centres and g is the gavitational force vector.
You can get the eddy viscosity from the turbulence model and write it out.
henry is offline   Reply With Quote
Old   April 2, 2006, 09:24
Default Hello, I also have a simila
  #28
nicolas
nico765 is on a distinguished road
I also have a similar problem at the inlet of my 3d domain. As shown in the following pictures (with isosurface at gamma=0.5) (t=0.03), soon after the start of the computation, a 'wave' is developing near the inlet, and gets bigger and bigger.
meshCheck is ok.
my boundaries
pd:
boundaryField
inlet
type zeroGradient;
inlet:002
type zeroGradient;
outlet
type zeroGradient;
bottom
type zeroGradient;
top
type totalPressure;
p0 uniform 0;
value uniform 0;
right
type zeroGradient;
hull
type zeroGradient;
sym
type zeroGradient;
U:
boundaryField
inlet
type fixedValue;
value uniform (0.5 0 0);
inlet:002
type fixedValue;
value uniform (2 0 0);
outlet
type zeroGradient;
top
type pressureInletOutletVelocity;
phi phi;
rho rho;
value uniform (0 0 0);
bottom
type fixedValue;
sym
type fixedValue;
right
type fixedValue;
hull
type fixedValue;
nico765 is offline   Reply With Quote
Old   April 2, 2006, 14:38
Default As I said before, OF is not re
  #29
liu
Xiaofeng Liu
liu is on a distinguished road
As I said before, OF is not ready for open channel yet. At least the inlet and outlet boundary conditions will cause problem.
Xiaofeng Liu, Ph.D., P.E.,
Assistant Professor
Department of Civil and Environmental Engineering
Penn State University
223B Sackett Building
University Park, PA 16802
Web: http://water.engr.psu.edu/liu/
liu is offline   Reply With Quote
Old   April 2, 2006, 20:56
Default Hi liu,nicolas i did numeri
  #30
kumar
kumar2 is on a distinguished road
Hi liu,nicolas
i did numerical simulations of a 2d hydrofoil in a channel. my preliminary results are 100% ok. i also had issues with the correct BC. but the VOF works for open channel flows. nicolas , please see my posts rasInterFoam - STRANGE RESULTS AT BOUNDARY . after i incorporated Hrv's suggestions my simulations went smooth
regards
kumar
kumar2 is offline   Reply With Quote
Old   April 3, 2006, 11:47
Default Hi, kumar, Which post are you
  #31
liu
Xiaofeng Liu
Hi, kumar,
Which post are you refering to? I can't find it. Can you upload your case? I am so interested to see where I did wrong.
Thank you.
Assistant Professor
Old   April 3, 2006, 14:22
Default It's here http://www.cfd-onli
  #32
nicolas
It's here
http://www.cfd-online.com/cgi-bin/Op...show.cgi?1/656
Old   April 3, 2006, 14:25
Default oops, actually it s this one
  #33
nicolas
http://www.cfd-online.com/OpenFOAM_D...es/1/2014.html
Old   April 4, 2006, 04:07
Default I have checked the thread, but
  #34
nicolas
I have checked the thread, but i do something similar in my case. My problem is at the inlet and not at the outlet.
Old   July 4, 2006, 10:06
Default Can anyone supply or point me
  #35
Eugene de Villiers
Can anyone supply or point me toward an implementation of outlet boundary conditions for free surface wave transmission?
Old   November 5, 2007, 11:27
Default Hallo, I have the following
  #36
Karl-Heinz Leitz
khleitz is on a distinguished road
Hallo,
I have the following problem: I have a solid surrounded by air that moves from the left to the right with a constant velocity. However I get a very high pressure wave on the interface solid-air at the inlet and at the outlet. I have the feeling, that something with the boundary conditions is wrong. Can anybody give me a hit what the problem could be?
Regards,
Karl-Heinz
P.S. I would like to add a picture of my problem. Can anybody tell me how to do that?
khleitz is offline   Reply With Quote
Old   November 5, 2007, 11:35
Default Hallo, concerning my problem
  #37
Karl-Heinz Leitz
Hallo,
concerning my problem with the strange pressure patterns on the interface solid air. Here is a picture of my current model.
I use a modified interFoam solver. However these pressure waves make my silulation unstable.
Best regards,
Karl-Heinz
Old   September 29, 2009, 18:31
santiagomarquezd's Avatar
Santiago Marquez Damian
santiagomarquezd will become famous soon enough
Hi all, I'm dealing with surface problems in interFoam, the post is:
Setting up interFoam for sloshing
Any comments are welcome. Regards.
Santiago MÁRQUEZ DAMIÁN, Ph.D.
Research Scientist
Research Center for Computational Methods (CIMEC) - CONICET/UNL
Tel: 54-342-4511594 Int. 7032
Colectora Ruta Nac. 168 / Paraje El Pozo
(3000) Santa Fe - Argentina.
http://www.cimec.org.ar
santiagomarquezd is offline   Reply With Quote
Old   January 7, 2012, 23:43
Default VOF Method
  #39
ehsan
ehsan is on a distinguished road
Dear All
Could I ask you whether you could tell me which VOF technique is used in OpenFOAM? I mean there are different VOF models like Hirt and Nicols, Youngs, and so on. Which one is used in OpenFOAM?
Regards
Ehsan
ehsan is offline   Reply With Quote
Old   January 8, 2012, 10:45
Nima Samkhaniani
nimasam is on a distinguished road
Dear ehsan
1) please ask your question just in one post, not in several posts!
2) look this paper:
BRACKBILL, J. U., KOTHE, D. B. & ZEMACH, C. 1992. A Continuum Method for Modeling Surface Tension. Journal of Computational Physics, 100, 335-354.
this method reduces need for interface reconstruction, this method interface is smeared among 2 or 3 cells and it uses a high order schemes
and interface compression method to keep interface sharp
3) if you uses interFoam solver look at here:
BERBEROVIĆ, E., HINSBERG, N. P. V., JAKIRLIĆ, S., ROISMAN, I. V. & TROPEA, C. 2009. Drop impact onto a liquid layer of finite thickness: Dynamics of the cavity evolution. The American Physical Society, 79, 036306 (15).
4)if you look for more, look at here:
Rusche, H., Computational Fluid Dynamics of Dispersed Two-Phase Flows at High Phase Fractions,
in Department of Mechanical Engineering. 2002, Imperial college of Science: University of London
nimasam is offline   Reply With Quote
Thread Tools
Trackbacks are On
2d interface Rogerio Fernandes Brito CFX 2 July 26, 2008 12:25
interface rym FLUENT 2 January 16, 2008 05:55
About Interface BC Philip FLUENT 0 January 3, 2008 02:51
How to set BC at the interface K Tamemy FLUENT 0 June 5, 2006 10:45
interface braket FLUENT 1 November 15, 2005 02:58
