I am working on a custom solve
I am working on a custom solver that requires I use the solve function a number of times during my solution. Unfortunately, This leads to a very large number of the summary lines being output to the terminal window, i.e.:
DICPCG: Solving for gamma, Initial residual = 0.000100881, Final residual = 1.64739e-12, No Iterations 1 Is there any way to temporarily disable the summary output to the terminal within the solver code, and then re-enable it following the section where the large number of equations are solved. Thanks, Adam |
I see that under the lduMatrix
I see that under the lduMatrixTests.C file a debug switch is checked to see if a summary of the solution statistics should be printed to the screen.
Is there a way to either modify this switch during runtime, or define an lduMatrix that has a set debug switch = 0?. |
Yes. In the code, you can do
lduMatrix::debug = 0; or edit $HOME/.OpenFOAM-1.4.1-dev/controlDict and set lduMatrix debug switch to zero. Enjoy, Hrv |
Great. Thank you
Great. Thank you
