Hello
Do you know which one
Hello
Do you know which one, OpenMP or MPI, OpenFOAM use? regards mou |
OpenMPI is the dault for openf
OpenMPI is the dault for openfoam 1.4.1.
Ning |
I know that OpenFOAM use it's
I know that OpenFOAM use it's openmpi with version 1.2.3. If I want to use another Openmpi or other parallization stuff like HP_MPI how can I do that?
Can I do that without compiling the whole code? Regards, mou |
Yes. Read my post on HP-MPI. I
Yes. Read my post on HP-MPI[1]. I was able to rebuild the parallel library, libPstream.so (which is the only major thing you need to rebuild when switching MPI libraries) with some tweaking.
[1] http://www.cfd-online.com/OpenFOAM_D...es/1/5302.html |
Please check the post for an u
Please check the post for an update by Eugene for HPMPI.
