-   -   Parallel processing problem with mpich (http://www.cfd-online.com/Forums/openfoam-solving/59377-parallel-processing-problem-mpich.html)
nzy102 October 16, 2007 19:25
Hi guys: I have been stuck
Hi guys:
I have been stuck with a parallel processing on openfoam 1.4.1. I tested a case with 2.3 million cells. After tested several different node numbers, I found that a lot of time has been wasted by using openmpi. Then I decided to switch to other mpich packages on my school cluster. Here is what I did:
export MPICH_PATH=/usr/global/mpich-infinicon
export MPICH_ARCH_PATH=$MPICH_PATH/platforms/$WM_OPTIONS
export MPICH_ROOT=$MPICH_ARCH_PATH
AddLib $MPICH_ARCH_PATH/lib
AddPath $MPICH_ARCH_PATH/bin
export FOAM_MPI_LIBBIN=$FOAM_LIBBIN/mpich-infinicon
The problem is I don't have permission to write in /global/mpich-infinicon. I am wondering if I really have to put "platforms/$WM_OPTIONS", "lib" and "bin" in the global directory or there is other way around. Thank you for help.
Ning
mattijs October 17, 2007 03:24
It is the AddLib & AddPath I a
It is the AddLib & AddPath I assume that give the problems since they do an 'mkdir' under the hood. Remove the mkdir from the AddLib and AddPath and see if that works.
nzy102 October 17, 2007 10:25
I tried ./Allwmake in ..src/Ps
I tried ./Allwmake in ..src/Pstream directory. I got an error:
+ '[' MPICH = LAM -o MPICH = OPENMPI -o MPICH = MPI -o MPICH = MPICH -o MPICH = MPICH-GM -o MPICH = MPIGAMMA ']'
+ export WM_OPTIONS=linux64GccDPOptMPICH
+ WM_OPTIONS=linux64GccDPOptMPICH
+ wmake libso mpi
/usr/bin/ld: cannot find -lmpich
collect2: ld returned 1 exit status
Then I followed the link (http://openfoamwiki.net/non_cdl/Open...mpile_OpenFOAM)and installed binutil-2.18. I got the error as follows:
+ wmake libso mpi
/home1/nzy102/OpenFOAM/linux64/binutils-2.18/bin/ld: cannot find -lmpich
make: *** [/home1/nzy102/OpenFOAM/OpenFOAM-1.4.1/lib/linux64GccDPOpt/mpich-infinicon/libPs tream.so] Error 1
msrinath80 October 17, 2007 11:27
Check whether /usr/global/mpic
Check whether /usr/global/mpich-infinicon/lib contains *.a (static) or *.so (shared) libraries. I am guessing that it contains only *.a files. To build libPstream.so successfully, you need *.so files in there. Mattijs, please correct me if I am wrong.
nzy102 October 17, 2007 12:02
Thanks,Srinath. I changed my .
Thanks,Srinath. I changed my .bashrc and now I made a new libPstream.so. This is what I used in my .bashrc:
# export MPICH_VERSION=infinicon-3.1.0.0.35G
# export MPICH_ARCH_PATH=$MPICH_PATH/platforms/$WM_OPTIONS
# AddLib $MPICH_ARCH_PATH/lib
# AddPath $MPICH_ARCH_PATH/bin
# export FOAM_MPI_LIBBIN=$FOAM_LIBBIN/mvapich-$MPICH_VERSION
But when I submit my jobs using pbs file, I got an error:
icoFoam: symbol lookup error: /home1/nzy102/OpenFOAM/OpenFOAM-1.4.1/lib/linux64GccDPOpt/mpich-infinicon/libPst ream.so: undefined symbol: FStatusText
Anybody knows what this means? For the new mpich, what command I should use for parallel?
Should I still use something like:
mpirun -np 2 icoFoam /home1/nzy102/OpenFOAM/nzy102-1.4.1/run/tutorials/icoFoam lvad_90_0_5_grid2_np2 -parallel
Thank you.
Ning
msrinath80 October 17, 2007 12:12
Replace icoFoam with `which ic
Replace icoFoam with `which icoFoam` and it should work. MPICH usually needs the full path to icoFoam specified when using the mpirun command. e.g:
mpirun -np 2 `which icoFoam` /home1/nzy102/OpenFOAM/nzy102-1.4.1/run/tutorials/icoFoam lvad_90_0_5_grid2_np2 -parallel
msrinath80 October 17, 2007 12:15
You may also need to specify a
You may also need to specify a machinefile:
mpirun -np 2 -machinefile mymachinefile `which icoFoam_1` . mycase -parallel
Where mymachinefile contains:
hostname:number of processors
e.g.:
ning:2
Or you can give $PBS_NODEFILE instead of mymachinefile. e.g.:
mpirun -np 2 -machinefile $PBS_NODEFILE `which icoFoam_1` . mycase -parallel
msrinath80 October 17, 2007 12:25
Oh, and after you change to a
Oh, and after you change to a different MPI library, go to your application source and recompile the solver. For icoFoam, you need to go to ~/OpenFOAM/OpenFOAM-1.4/applications/solvers/incompressible/icoFoam/
and execute wclean && wmake there. That should take care of your symbol lookup errors, I think?
nzy102 October 17, 2007 12:45
Thank you for quick replied, S
Thank you for quick replied, Srinath. I compiled my icoFoam and got:
Making dependency list for source file icoFoam.C
SOURCE=icoFoam.C ; g++ -m64 -Dlinux64 -DDP -Wall -Wno-strict-aliasing -Wextra -Wno-unused-parameter -Wold-style-cast -march=opteron -O3 -DNoRepository -ftemplate-depth-40 -I/home1/nzy102/OpenFOAM/OpenFOAM-1.4.1/src/finiteVolume/lnInclude -IlnInclude -I. -I/home1/nzy102/OpenFOAM/OpenFOAM-1.4.1/src/OpenFOAM/lnInclude -fPIC -c $SOURCE -o Make/linux64GccDPOpt/icoFoam.o
In file included from icoFoam.C:105:
computeMassFlux.H:17:2: warning: no newline at end of file
g++ -m64 -Dlinux64 -DDP -Wall -Wno-strict-aliasing -Wextra -Wno-unused-parameter -Wold-style-cast -march=opteron -O3 -DNoRepository -ftemplate-depth-40 -I/home1/nzy102/OpenFOAM/OpenFOAM-1.4.1/src/finiteVolume/lnInclude -IlnInclude -I. -I/home1/nzy102/OpenFOAM/OpenFOAM-1.4.1/src/OpenFOAM/lnInclude -fPIC Make/linux64GccDPOpt/icoFoam.o -L/home1/nzy102/OpenFOAM/OpenFOAM-1.4.1/lib/linux64GccDPOpt \
-lfiniteVolume -lOpenFOAM -liberty -ldl -lm -o /home1/nzy102/OpenFOAM/OpenFOAM-1.4.1/applications/bin/linux64GccDPOpt/icoFoam
/home1/nzy102/OpenFOAM/OpenFOAM-1.4.1/lib/linux64GccDPOpt/mpich-infinicon/libPst ream.so: undefined reference to `FStatusText'
/home1/nzy102/OpenFOAM/OpenFOAM-1.4.1/lib/linux64GccDPOpt/mpich-infinicon/libPst ream.so: undefined reference to `ib_vapi_cm_prepare'
/home1/nzy102/OpenFOAM/OpenFOAM-1.4.1/lib/linux64GccDPOpt/mpich-infinicon/libPst ream.so: undefined reference to `iba_wc_status_msg'
/home1/nzy102/OpenFOAM/OpenFOAM-1.4.1/lib/linux64GccDPOpt/mpich-infinicon/libPst ream.so: undefined reference to `EVAPI_clear_async_event_handler'
/home1/nzy102/OpenFOAM/OpenFOAM-1.4.1/lib/linux64GccDPOpt/mpich-infinicon/libPst ream.so: undefined reference to `VAPI_get_iba_cq'
/home1/nzy102/OpenFOAM/OpenFOAM-1.4.1/lib/linux64GccDPOpt/mpich-infinicon/libPst ream.so: undefined reference to `VAPI_create_qp'
/home1/nzy102/OpenFOAM/OpenFOAM-1.4.1/lib/linux64GccDPOpt/mpich-infinicon/libPst ream.so: undefined reference to `FCmStatusText'
/home1/nzy102/OpenFOAM/OpenFOAM-1.4.1/lib/linux64GccDPOpt/mpich-infinicon/libPst ream.so: undefined reference to `VAPI_event_syndrome_sym'
/home1/nzy102/OpenFOAM/OpenFOAM-1.4.1/lib/linux64GccDPOpt/mpich-infinicon/libPst ream.so: undefined reference to `EVAPI_clear_comp_eventh'
/home1/nzy102/OpenFOAM/OpenFOAM-1.4.1/lib/linux64GccDPOpt/mpich-infinicon/libPst ream.so: undefined reference to `VAPI_deregister_mr'
/home1/nzy102/OpenFOAM/OpenFOAM-1.4.1/lib/linux64GccDPOpt/mpich-infinicon/libPst ream.so: undefined reference to `VAPI_query_qp'
/home1/nzy102/OpenFOAM/OpenFOAM-1.4.1/lib/linux64GccDPOpt/mpich-infinicon/libPst ream.so: undefined reference to `EVAPI_set_async_event_handler'
/home1/nzy102/OpenFOAM/OpenFOAM-1.4.1/lib/linux64GccDPOpt/mpich-infinicon/libPst ream.so: undefined reference to `VAPI_alloc_pd'
/home1/nzy102/OpenFOAM/OpenFOAM-1.4.1/lib/linux64GccDPOpt/mpich-infinicon/libPst ream.so: undefined reference to `VAPI_strerror'
/home1/nzy102/OpenFOAM/OpenFOAM-1.4.1/lib/linux64GccDPOpt/mpich-infinicon/libPst ream.so: undefined reference to `ib_vapi_cm_disconnect'
/home1/nzy102/OpenFOAM/OpenFOAM-1.4.1/lib/linux64GccDPOpt/mpich-infinicon/libPst ream.so: undefined reference to `iba_poll_cq'
/home1/nzy102/OpenFOAM/OpenFOAM-1.4.1/lib/linux64GccDPOpt/mpich-infinicon/libPst ream.so: undefined reference to `iba_poll_cq_wait'
/home1/nzy102/OpenFOAM/OpenFOAM-1.4.1/lib/linux64GccDPOpt/mpich-infinicon/libPst ream.so: undefined reference to `ib_vapi_cm_finalize'
/home1/nzy102/OpenFOAM/OpenFOAM-1.4.1/lib/linux64GccDPOpt/mpich-infinicon/libPst ream.so: undefined reference to `VAPI_create_cq'
/home1/nzy102/OpenFOAM/OpenFOAM-1.4.1/lib/linux64GccDPOpt/mpich-infinicon/libPst ream.so: undefined reference to `VAPI_destroy_cq'
/home1/nzy102/OpenFOAM/OpenFOAM-1.4.1/lib/linux64GccDPOpt/mpich-infinicon/libPst ream.so: undefined reference to `iba_post_recv2'
/home1/nzy102/OpenFOAM/OpenFOAM-1.4.1/lib/linux64GccDPOpt/mpich-infinicon/libPst ream.so: undefined reference to `iba_post_send2'
/home1/nzy102/OpenFOAM/OpenFOAM-1.4.1/lib/linux64GccDPOpt/mpich-infinicon/libPst ream.so: undefined reference to `VAPI_destroy_qp'
/home1/nzy102/OpenFOAM/OpenFOAM-1.4.1/lib/linux64GccDPOpt/mpich-infinicon/libPst ream.so: undefined reference to `VAPI_register_mr'
/home1/nzy102/OpenFOAM/OpenFOAM-1.4.1/lib/linux64GccDPOpt/mpich-infinicon/libPst ream.so: undefined reference to `EVAPI_set_comp_eventh'
/home1/nzy102/OpenFOAM/OpenFOAM-1.4.1/lib/linux64GccDPOpt/mpich-infinicon/libPst ream.so: undefined reference to `iba_wc_type_msg'
/home1/nzy102/OpenFOAM/OpenFOAM-1.4.1/lib/linux64GccDPOpt/mpich-infinicon/libPst ream.so: undefined reference to `VAPI_event_record_sym'
/home1/nzy102/OpenFOAM/OpenFOAM-1.4.1/lib/linux64GccDPOpt/mpich-infinicon/libPst ream.so: undefined reference to `VAPI_dealloc_pd'
/home1/nzy102/OpenFOAM/OpenFOAM-1.4.1/lib/linux64GccDPOpt/mpich-infinicon/libPst ream.so: undefined reference to `ib_vapi_cm_init'
/home1/nzy102/OpenFOAM/OpenFOAM-1.4.1/lib/linux64GccDPOpt/mpich-infinicon/libPst ream.so: undefined reference to `ib_vapi_cm_connect'
/home1/nzy102/OpenFOAM/OpenFOAM-1.4.1/lib/linux64GccDPOpt/mpich-infinicon/libPst ream.so: undefined reference to `VAPI_get_iba_qp'
Something is messed up with my new libpstream.so.
Ning
msrinath80 October 17, 2007 12:53
computeMassFlux.H is not a sta
computeMassFlux.H is not a standard part of icoFoam is it? Are you sure that it has been parallelized properly?
Try this. Recompile the original icoFoam solver and see if you get these errors. I'm sorry I cannot offer more guidance. I don't know what could be wrong. Please wait for Mattijs to respond. He is the parallel expert http://www.cfd-online.com/OpenFOAM_D...part/happy.gif
nzy102 October 17, 2007 13:03
Srinath: ComputeMassFlux wo
Srinath:
ComputeMassFlux works with openmpi. You can ignore the computemassflux. Thank you for all the suggestions.
Mattijs:
Can you take a look at this case when you get a chance?
Thank you.
mbeaudoin October 17, 2007 15:59
Hello Ning, 1: By commentin
Hello Ning,
1: By commenting out
you won't be able to run your MPI application because your LD_LIBRARY_PATH environment variable will not be set properly to find the MPI runtime libraries needed.
2: By commenting out
you won't be able to use the proper version of mpirun associate with your local version of MPI. You might (and probably will) run into problems.
3: About your compilation problems and the numerous error messages associated to libPstream:
You are probably missing one or more libraries that need to be specified with libmpich.
Find someone at your location who has already compiled an application with your local version of MPICH, and look at the list of libraries that need to be specified for linking such an application.
Martin
nzy102 October 17, 2007 19:15
Hi Martin: I linked the lib
Hi Martin:
I linked the library required to icofoam solver and now it works fine. I still have addlib and addpath commented out and hasn't seen any problem so far. Since I don't have permission to write in the global directory, I am gonna leave it there. Thank you.
Ning
mbeaudoin October 17, 2007 22:45
Hello Ning, For your inform
Hello Ning,
For your information, you don't need write access to your global /global/mpich-infinicon directory.
I am using a local openmpi version on my cluster, and I don't have write access there either. Don't need to.
Addlib() and AddPath() are defined in the file $WM_PROJECT_DIR/.bashrc.
Take a look at their definition:
AddPath(){
export PATH=$1:$PATH
if [ ! -d $1 ]; then
mkdir -p $1
fi
AddLib(){
export LD_LIBRARY_PATH=$1:$LD_LIBRARY_PATH
mkdir -p $1
fi
See the lines in red? What this means is that if the path used as parameter to the functions AddLib and AddPath don't exists, then mkdir will try to create it.
So if you use a valid path when calling AddLib and AddPath, mkdir will never ever get called in the first place.
Check the validity of your paths when using AddLib and AddPath.
From your example, the paths you are using are probably wrong in the first place because
$MPICH_ARCH_PATH/lib would expand to
$MPICH_PATH/platforms/$WM_OPTIONS/lib which would probably looks like
/usr/global/mpich-infinicon/platforms/linuxGccDPOpt/lib.
I doubt this is a valid path on your system, hence the problem with mkdir when using AddLib.
What you probably want instead in your .bashrc is :
export MPICH_ROOT=$MPICH_PATH
AddLib $MPICH_PATH/lib
AddPath $MPICH_PATH/bin
Your cluster sysadmin probably set up your initial user environment properly for using the /global/mpich-infinicon libraries and binaries by default, this is why your setup does work even though the two important lines Addlib and AddPath are commented out.
Martin
nzy102 October 18, 2007 00:05
Now everything is clear to me.
Now everything is clear to me. Thank you so much.
Ning
