Home > Forums > OpenFOAM Running, Solving & CFD
TestWallDist does not work with 1D mesh
Old   October 11, 2007, 16:33
Default I have a 1D mesh with top be a
liu
Xiaofeng Liu
liu is on a distinguished road
I have a 1D mesh with top be a wall. What I want is the distance from all cells to that wall. Simple enough?
When I do
testWallDist . test
I got error like this:
--> FOAM FATAL ERROR : Maximum number of iterations reached. Increase maxIter.
maxIter:1000
nChangedCells:0
nChangedFaces:5
From function meshWave<type>::meshWave(const polyMesh&, const labelList&, const List<type>&, const label maxIter)
in file /home/liu19/research/OpenFOAM/OpenFOAM-1.3/src/OpenFOAM/lnInclude/meshWave.C at line 846.
here is the simple test case:
test.tar.gz
Xiaofeng Liu, Ph.D., P.E.,
Assistant Professor
Department of Civil and Environmental Engineering
Penn State University
223B Sackett Building
University Park, PA 16802
Web: http://water.engr.psu.edu/liu/
liu is offline   Reply With Quote
Old   October 11, 2007, 17:49
Default Wall distance travels one cell
Mattijs Janssens
mattijs is on a distinguished road
Wall distance travels one cell per iteration. You have max 1000 iterations set up. How many cells 'thick' is your mesh?
mattijs is offline   Reply With Quote
Old   October 11, 2007, 21:19
Default I have 1000 cells in this simp
liu
Xiaofeng Liu
I have 1000 cells in this simple 1D mesh.
The maxIter is not set by me. I found maxIter is set as the mesh cell numbers which I am quite confused.
Here is from src/meshTools/cellDist/patchWave/patchWave.C
meshWave<wallpoint> waveInfo
mesh(),
changedFaces,
faceDist,
mesh().nCells() // max iterations
Assistant Professor
Old   October 12, 2007, 04:19
Default Change the maxIter to a bit mo
Mattijs Janssens
Change the maxIter to a bit more than mesh().nCells() and recompile.
Thread Tools
Trackbacks are On
cvd can't work mahe Phoenics 0 February 25, 2008 23:01
CFD mesh in work bench sach Main CFD Forum 0 October 31, 2006 03:11
Button 'Generate Mesh' doesn't work Julie Polyakh CD-adapco 3 January 7, 2004 19:15
CFX 5.5.1 for 2D work blair CFX 9 May 20, 2003 10:29
visual3 can't work with refined mesh dell CD-adapco 0 December 15, 2002 06:00
