September 19, 2007, 09:00 |
The tutorial concerning diesel
Tomislav Sencic
The tutorial concerning diesel is done with heptane C7H16. I would like to use different hidrocarbons, for example C12H26. I know I have to change the species, the reactions and the coeffs in chemkin/chem.inp and the nasa polinomials in chemkin/term.dat. I supose also in constant/thermophysicalproperties i should ad some coeffs but I do not know how.
What do I have to change to use a different fuel then those mentioned in chemkin/therm.dat? |
September 21, 2007, 04:25 |
I found the IDEA fuel in the s
Tomislav Sencic
I found the IDEA fuel in the src/thermophysicalModels/liquids directory, but I do not know how to use it.
What do I have to do in order to use the IDEA fuel? |
September 21, 2007, 04:44 |
Hi. Tomislav
You can use th
Hi. Tomislav
You can use the fuel by changing the liquidFuelComponents in constant/thermophysicalProperties. |
September 21, 2007, 05:59 |
Thanks.
I tried but I receive
Tomislav Sencic
Thanks.
I tried but I receive again some errors. Do I have to change the reactions and the species in chem.inp? Do I have to put the reactions for both the components of IDEA (C10H7-CH3 and N-C10H22(DECANE)? Where can I find the reaction coefficients? Do I have to change something in chemkin/thermo.dat? |
September 21, 2007, 07:08 |
I tried to use C14H30. I chang
Tomislav Sencic
I tried to use C14H30. I changed chem.inp with the reaction
2C14H30 + 43O2 => 28CO2 + 30H2O but I get --> FOAM FATAL ERROR : Elemental imbalance in H in reaction irreversibleArrheniusReaction 2C14H30^0.25 + 43O2^1.5 = 28CO2 + 30H2O (2.81171e+06 0 7940.36) on line 10 What is the reason? |
September 21, 2007, 08:05 |
Hi Tomislav,
Try with the
Tommaso Lucchini
Hi Tomislav,
Try with the following C14H30 + 21.5 O2 => 14CO2 + 15H2O and see what happens. bye |
September 21, 2007, 08:13 |
Shouldn't you be usi
Guido Adriaensen
Shouldn't you be using: C14H30 + 21 O2 => 14 CO2 + 15 H2O The O was in imbalance. Guido |
September 21, 2007, 08:15 |
Sorry,
Never mind my post :
Guido Adriaensen
Sorry,
Never mind my post :-) Thought there was something else written there. Tommaso's post was correct, sorry again. |
September 21, 2007, 08:45 |
Tomislav,
it seems to be so
Tommaso Lucchini
Tomislav,
it seems to be something related to the coefficients: FORD / C14H30 0.25 / FORD / O2 1.5 / Try to investigate what they mean. |
September 21, 2007, 08:55 |
Yes, I just left them from the
Tomislav Sencic
Yes, I just left them from the tutorial for C7H16. I 'll try to investigate.
Anyway, thanks |
November 8, 2011, 03:53 |
#11 |
Abhishek
Hi everyone,
I am trying to run sprayFoam. I am using C12H26 and have added the specie in therm.dat and reaction in chem.inp. ELEMENTS H O C N AR END SPECIE C12H26 O2 N2 CO2 H2O END REACTIONS 2C12H26 + 37O2 => 24CO2 + 26H2O 3.00E+5 0.0 15780.0! 1 FORD / C12H26 0.75 / FORD / O2 1.5 / END I am getting following error. --> FOAM FATAL ERROR: Elemental imbalance in H in reaction irreversibleArrheniusReaction 2C12H26^0.75 + 37O2^1.5 = 24CO2 + 26H2O on line 10 From function chemkinReader::addReaction in file chemistryReaders/chemkinReader/chemkinReader.C at line 782. FOAM exiting Where is the imbalance? |
February 16, 2012, 13:25 |
#12 |
Roberto Torelli
Hi everyone!
I have a question for Abhishekd18 (and also for everyone who could help me). Did you solve the problem of the reaction imbalance? I have the same problem and I also tried to divide by 2 all the reaction coefficients in order to have a unitary coefficient for the dodecane, but still nothing... Furthermore I have updated my therm.dat with the correct janaf coefficients, so I think the problem is related only to the chem.imp file. I hope you could help me and thanks in advance! :-) Roberto |
August 12, 2013, 14:51 |
#13 | |
Juan Manuel Mompó Laborda
Hi Abhishekd, Where did you get the JANAF coefficients for C12H26 from? Could you please share them? Thanks! Juanma |
Diesel fuel combustion | Marek | CFX | 1 | November 30, 2008 13:39 |
diesel fuel injection part Nozzle/Elment/D.valveVE | Michael weng | Main CFD Forum | 1 | April 4, 2006 21:46 |
Fuel Modelling in Diesel Engines, what's truth | Jo | Siemens | 0 | August 18, 2004 13:47 |
Spray and combustion model for alternative fuel | Torn | Main CFD Forum | 3 | November 12, 2003 04:05 |
Alternative to Gambit | chris | FLUENT | 1 | October 16, 2002 00:53 |
