Resistance boundary conditions
Like Tree1Likes
  • 1 Post By 7islands
Old   September 13, 2007, 21:57
Default Hey Guys: Has anybody here
Ning Yang
nzy102 is on a distinguished road
Hey Guys:
Has anybody here used resistance outflow boundary condition in openfoam? Basically what it does is to keep the ratio (resistance R) bewteen pressure P and flow rate Q constant at the outlet, instead of using constant pressure or other outlet boundary conditions? Assume that the pressure on the outlet cross section is constant.
Thank you.
Ning
nzy102 is offline   Reply With Quote
Old   September 14, 2007, 05:03
Default Hi Ning, If I'm not getting w
Takuya OSHIMA
7islands is on a distinguished road
Hi Ning,
If I'm not getting wrong might this thread be of any help to you? ...or not?
Takuya
ARTisticCFD likes this.
7islands is offline   Reply With Quote
Old   September 15, 2007, 12:09
Default Hi Takuya: Thank you for sh
Ning Yang
Hi Takuya:
Thank you for sharing your code. It is pretty close. The only difference is that I need to replace normal velocity by integral surface flow rate. The problem is when I tried to compile your code, I got some error like:
make: *** No rule to make target `/derived/normalIncidenceAcousticImpedance/normalIncidenceAcousticImpedanceFvPat chScalarField.dep', needed by `Make/linux64GccDPOpt/dependencies'. Stop.
Can you let me know why this happened? Thank you.
Ning
Old   September 17, 2007, 21:22
Default Hi Ning, Well, there are vari
Takuya OSHIMA
Hi Ning,
Well, there are various things you have to be careful about the code, at least:
  • as the posted date of the code obviously indicates, the code is to be used with OF 1.3. For newer OF versions you need to make modifications accordingly.
  • as the code was meant to be just an proof-of-cocept, it just calculates boundary p or U based on patch-internal cell-center value of the opposite variable (with the b. c. type set to zeroGradient). If you intend to make serious use of the code numerical discretization schemes must be carefully cosidered besides modification from flow velocity to flow rate.
Actually I myself no longer use nor maintain the code so you have to do above by yourself. Still, it should serve as a much better starting point compared to writing it from scratch all by yourself.
Good luck,
Takuya
Old   September 17, 2007, 22:23
Default Thank you for your reply. I fi
Ning Yang
Thank you for your reply. I figured the problem out and now I don't have any compilation errors. I have one more question though: can you explain the following line in your code?
operator==(2.0 * z_ * (n & Up) - *this);
It doesn't ring a bell for me. Thank you.
Ning
Old   September 19, 2007, 20:14
Default Hi Ning, It's an #if 0'ed l
Takuya OSHIMA
Hi Ning,
It's an #if 0'ed line anyway so please don't care. It's an updating equation if velocity and pressure are teken staggered in time ((*this<sub>new</sub> + *this<sub>old</sub>) / 2 = z_ * (n & Up)).
Takuya
Old   March 27, 2017, 03:54
sitajeje is on a distinguished road
Hallo Ning,
I want to build the same boundary condition as you did in 2007: the outlet pressure is dependent on the flow rate. I wonder whether you have solved your problem? I would appreciate if you could give me some hints how to program this boundary condition.
Thank you very much!
sitajeje
sitajeje is offline   Reply With Quote
Old   March 27, 2017, 03:58
Hello Takuya,
I downloaded your file normalIncidenceAcousticImpedance-20070112.tar.gz, but it turns out to be a .unk file, and I cannot unzip it. I would appreciate greatly if you could share your file again. Thank you very much in advance!
Best regards,
sitajeje
Old   June 27, 2018, 11:27
Pavan
pvpnrao is on a distinguished road
https://www.cfd-online.com/Forums/members/sitajeje.html
This is a very late response. Just posting for the community benefit
Assuming the OS is Linux/ubuntu
Just download the (.unk) file. Rename the file with .tar extension and the just untar it using the command
tar -xvf normalIncidenceAcousticImpedance-20070112_tar-3659.tar
I am posing a .zip file of the same folder. This can be easily opened using the command
unzip normalIncidenceAcousticImpedance.zip
pvpnrao is offline   Reply With Quote
Burgerbs equation non constant Boundary Conditions Initial Conditions arkangel OpenFOAM Running, Solving & CFD 1 October 2, 2008 14:48
Boundary conditions for turbulent boundary layer Thomas FLUENT 1 June 17, 2008 05:14
boundary conditions for boundary layer flow A. Al-zoubi CFX 0 November 3, 2007 07:11
boundary conditions for compute resistance of ship Bruce CFX 1 April 18, 2007 11:30
Integral boundary conditions turbulent intensitylength boundary conditions olesen OpenFOAM Running, Solving & CFD 0 July 27, 2006 07:18
