June 8, 2022, 09:56 |
simpleFoam parallel Error
Rep Power: 3 |
Hey everyone,
I'm running my commands blockMesh, surfaceFeatureExtract, decomposePar etc. and then I run the command: Code:
mpirun -np 6 simpleFoam -parallel Then I reposition my objects and my blockMesh and execute the same commands and when I execute "mpirun -np 6 simpleFoam -parallel" I get several warnings and simpleFoam stops working: Code:
WARNING: Linux kernel CMA support was requested via the btl_vader_single_copy_mechanism MCA variable, but CMA support is not available due to restrictive ptrace settings. The vader shared memory BTL will fall back on another single-copy mechanism if one is available. This may result in lower performance. Local host: DESKTOP-38LT3B8 -------------------------------------------------------------------------- /*---------------------------------------------------------------------------*\ | ========= | | | \\ / F ield | OpenFOAM: The Open Source CFD Toolbox | | \\ / O peration | Version: v2012 | | \\ / A nd | Website: www.openfoam.com | | \\/ M anipulation | | \*---------------------------------------------------------------------------*/ Build : _7bdb509494-20201222 OPENFOAM=2012 Arch : "LSB;label=32;scalar=64" Exec : simpleFoam -parallel Date : Jun 08 2022 Time : 15:16:33 Host : DESKTOP-38LT3B8 PID : 4309 I/O : uncollated Case : /home/sedat_szr/OpenFOAM/sedat_szr-v2012/run/WindBuildings nProcs : 6 Hosts : ( (DESKTOP-38LT3B8 6) ) Pstream initialized with: floatTransfer : 0 nProcsSimpleSum : 0 commsType : nonBlocking polling iterations : 0 trapFpe: Floating point exception trapping enabled (FOAM_SIGFPE). fileModificationChecking : Monitoring run-time modified files using timeStampMaster (fileModificationSkew 5, maxFileModificationPolls 20) allowSystemOperations : Allowing user-supplied system call operations // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // Create time Create mesh for time = 0 SIMPLE: convergence criteria field p tolerance 1e-05 field U tolerance 1e-06 field "(k|epsilon)" tolerance 1e-06 Reading field p Reading field U Reading/calculating face flux field phi AMI: Creating addressing and weights between 2877 source faces and 2877 target faces --> FOAM Warning : From void Foam::advancingFrontAMI::checkPatches() const in file AMIInterpolation/AMIInterpolation/advancingFrontAMI/advancingFrontAMI.C at line 71 Source and target patch bounding boxes are not similar source box span : (500 0 115) target box span : (-2e+150 -2e+150 -2e+150) source box : (386050 5819800 35) (386550 5819800 150) target box : (1e+150 1e+150 1e+150) (-1e+150 -1e+150 -1e+150) inflated target box : (8.26794919243e+149 8.26794919243e+149 8.26794919243e+149) (-8.26794919243e+149 -8.26794919243e+149 -8.26794919243e+149) --> FOAM Warning : From bool Foam::advancingFrontAMI::initialiseWalk(Foam::label&, Foam::label&) in file AMIInterpolation/AMIInterpolation/advancingFrontAMI/advancingFrontAMI.C at line 132 1302 source faces but no target faces AMI: Patch source sum(weights) min:0 max:0 average:0 AMI: Patch target sum(weights) min:0 max:0 average:0 Selecting incompressible transport model Newtonian Selecting turbulence model type RAS Selecting RAS turbulence model kEpsilon bounding k, min: 0 max: 1.51129104574 average: 1.51129104574 bounding epsilon, min: 0 max: 0.1 average: 0.1 kEpsilonCoeffs { Cmu 0.09; C1 1.44; C2 1.92; sigmaEps 1.11; C3 0; sigmak 1; } No MRF models present No finite volume options present Starting time loop Time = 1 smoothSolver: Solving for Ux, Initial residual = 0.999999999999, Final residual = 9.51841330334e-09, No Iterations 20 smoothSolver: Solving for Uy, Initial residual = 1, Final residual = 4.83333164882e-09, No Iterations 22 smoothSolver: Solving for Uz, Initial residual = 1, Final residual = 2.73654459038e-09, No Iterations 20 -------------------------------------------------------------------------- Primary job terminated normally, but 1 process returned a non-zero exit code. Per user-direction, the job has been aborted. -------------------------------------------------------------------------- -------------------------------------------------------------------------- mpirun detected that one or more processes exited with non-zero status, thus causing the job to be terminated. The first process to do so was: Process name: [[47863,1],0] Exit code: 142 -------------------------------------------------------------------------- [DESKTOP-38LT3B8:04305] 5 more processes have sent help message help-btl-vader.txt / cma-permission-denied [DESKTOP-38LT3B8:04305] Set MCA parameter "orte_base_help_aggregate" to 0 to see all help / error messages Thanks for any help, sezer Last edited by sezer; June 8, 2022 at 16:07. |
Display Modes | |
[OpenFOAM] Native ParaView Reader Bugs | tj22 | ParaView | 270 | January 4, 2016 12:39 |
ParaView for OF-1.6-ext | Chrisi1984 | OpenFOAM Installation | 0 | December 31, 2010 07:42 |
CGNS lib and Fortran compiler | manaliac | Main CFD Forum | 2 | November 29, 2010 07:25 |
checking the system setup and Qt version | vivek070176 | OpenFOAM Installation | 22 | June 1, 2010 13:34 |
user subroutine error | CFDUSER | CFX | 2 | December 9, 2006 07:31 |
