August 30, 2007, 11:20 |
for the purposes of matching s
Ken Darcovich
for the purposes of matching some reference points to data, I would like to be able to specify a geometrical point ie; (x,y,z) coordinate values, and have a cell index corresponding to that position returned.
Any ideas on how to do this would be most appreciated. |
August 30, 2007, 11:24 |
Have a look at Probe and relat
Hrvoje Jasak
Rep Power: 33 |
Have a look at Probe and related classes - they will give you a data stream for selected field in a specified point in space.
Hrv
August 30, 2007, 11:26 |
what I wanted to add to the ab
Ken Darcovich
what I wanted to add to the above message is something along the lines of:
the above question is surely a typical wish of a lot of new OF users, and it must have already been asked on this forum, but I'm NEVER able to find simple tips like this when I search this site. Same thing with the simple thing like using Foam::pow(a,b) for real exponents, the manual just says pow(a,b) and doesn't make the explicit distinction between integer and real cases. As everyone knows, simple simple problems like this are enough to halt work, and I'm frustrated that I always know exactly WHAT to do, but often cannot find HOW to do it. are there some tips on searching this site, or some kind of searchable archive of this kind of practical tips for OF?? thanks. |
August 30, 2007, 11:49 |
probe seems to extract FIELD v
Ken Darcovich
probe seems to extract FIELD values at points, I don't want that, I want the CELL NUMBER at a given point?
Is it possible to get the cell index with probe?? |
August 30, 2007, 12:20 |
Much easier:
mesh.findCell(
Hrvoje Jasak
Rep Power: 33 |
Much easier:
mesh.findCell(point(1, 2, 3)); This gives you the cell index nearest to the point (1 2 3) or -1 if the point is outside of the mesh. Enjoy, Hrv P.S. Fantastic code, huh?
August 30, 2007, 13:15 |
Thanks!
back on the rails,
Ken Darcovich
Thanks!
back on the rails, headed for the next crash... |
March 5, 2010, 12:51 |
Hi Kdarc,
if you stop by here once in a while...would you mind posting the file in which you used the "mesh.findCell(point(x,y,z));" command ? regards |
March 23, 2010, 07:20 |
coordonate -> cell index
Dragos
Rep Power: 20 |
This was a need for me too, so here is the snippet:
#include "fvCFD.H" // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // int main(int argc, char *argv[]) { # include "setRootCase.H" # include "createTime.H" # include "createMesh.H" // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // Info<< "\nindex of the closest cell to (0,0,0): " << mesh.findCell(point(0,0,0)) << "\n" << endl; return(0); } //************************************************************ // |
March 23, 2010, 09:01 |
Dragos
Rep Power: 20 |
How does the mesh.findCell(point(0,0,0)) work in parallel?
It returns -1 if the point is not inside the partition, which obviously will happen for all the partitions but one. What is the usual way to set the reference pressure for a parallel computation? Dragos Last edited by dmoroian; March 24, 2010 at 04:34. |
February 2, 2013, 11:07 |
Hi!
I'm quite new to on all this OpenFoAM thing and I need you help. When you talk about getting the cell index by the reference of a point, if it is contained in any cell, how do you send the command. I've been working with python to execute the simulation, stop it, rewrite some files etc.. but I dunno how to launch the command to get those. Where do I have to put the lines you told? Thank you in advantage, and sorry for that elementary question. |
February 2, 2013, 12:06 |
#11 | |
Dragos
Rep Power: 20 |
The line "mesh.findCell(point(0,0,0))" is usually put in a solver or utility, then it is compiled, and finally executed. What you mention about python is usually related to the execution stage (and most likely not yet implemented). Dragos |
February 2, 2013, 12:35 |
#12 |
Hi and thanks Dragos,
Sorry for not presenting myself, I'm Sergi. Ok I see how it works, but what I was really looking for is a command to be thrown from the terminal like I say "setFields" or "icoFoam". Isthere anything like that?? Thanks again! Sergi |
February 2, 2013, 12:50 |
#13 |
Dragos
Rep Power: 20 |
Not as far as I'm aware, but just for that, I think it would be very easy to write your own utility. One that gets as input the coordinates and outputs the index. However, I'm not sure what would you do with that index.
Dragos |
February 2, 2013, 12:54 |
#14 |
Thanks again Dragos,
Actually I'm using interFoam to run a multiphase simulation, and i want to substract and add fluid to certain points. Adding it is easy, i've done it using setfields, but the thing substracting it. The alphas are ordered by cell index, if I know the coordinates from where I've to substract the fluid i can find the cell and it's index. Maybe there other ways to sort it out. Thanks anyway, I'll give another thought to all of that. Thanks, sergi |
June 1, 2017, 22:54 |
#15 |
Dominic
Rep Power: 9 |
Dear dmoroian,
How about inputting the cell index and getting the cell center's coordinates returned ? Any comments are appreciated. Thanks. Dominic |
June 2, 2017, 00:42 |
#16 |
Dragos
Rep Power: 20 |
It's a long time since I've touched any openFoam codes, but I think it should be something like:
mesh.C().internalField()[i].component(0) |
June 2, 2017, 02:59 |
#17 |
Dominic
Rep Power: 9 |
Thank you for your quick reply!
I will give it a try! |
June 6, 2017, 23:30 |
#18 |
Dominic
Rep Power: 9 |
Dear dmoroian,
It really works! Thanks so much! |
May 7, 2020, 23:08 |
#19 | |
Fan
Rep Power: 5 |
How do you enter the velocity U in this code to get the grid center coordinates? Thanks, Fann |
February 18, 2021, 12:56 |
#20 |
Aaron Luchko
In parallel one can get find the processor (or processors) containing a cell using the following snippet.
Note this code runs on every processor, but only processor 0 will print Info statements. Code:
List<int> containing_cells(Pstream::nProcs()); int cell_index = mesh.findCell(point(10, .5, 0)); containing_cells[Pstream::myProcNo()] = cell_index; Pstream::gatherList(containing_cells); for (int proc = 0; proc < Pstream::nProcs(); proc++) { if (containing_cells[proc] != -1) { Info << "Proc " << proc << " has cell " << containing_cells[cell_index] << endl; } } |
UDF: Given coordinates, How to identify the cell? | Zhang | Fluent UDF and Scheme Programming | 26 | August 15, 2022 05:54 |
Cell index in fluent | Naresh | FLUENT | 0 | May 9, 2007 15:56 |
?? How to get cell center coordinates? | erica | FLUENT | 0 | May 11, 2005 22:02 |
How to get index of a cell by user subroutine? | windhair | CFX | 1 | November 19, 2003 10:30 |
How to get nodes coordinates for a certain cell ? | mikhail | FLUENT | 2 | November 1, 2000 10:18 |
