-   OpenFOAM Running, Solving & CFD (
-   -   Negative Pressure (
morteza August 26, 2007 11:28
Hi guys, I used lesInterFoam
Hi guys,
I used lesInterFoam to simulate flow around a wedge.
My boundary conditions are as follows:
Top and bottom boundaries are SYMMETRY
Left boundary is INLET
Right boundary is OUTLET
wedge boundary is WALL
I choose gamma=1 for both internal field and inlet value to disable the 2nd phase.
Uinlet=100 m/s poutlet=1.0e5 pas
rho=1000 nu=1.0e-6
But after solution the pressure is negative.
msrinath80 August 26, 2007 11:39
If the flow can be approximate
If the flow can be approximated as being incompressible, then I don't see anything wrong with the pressure being negative as only the pressure difference drives the flow.
Is the velocity field unphysical?
morteza August 26, 2007 11:45
Hi Madhavan, thanks for your
Hi Madhavan,
thanks for your reply
How can i make this negative pressure to possitive values.
I want to implement a cavitation model and must have possitive pressure.
thanks in advance
morteza August 26, 2007 12:09
I forgot to mention it. I sol
I solved this case with oodles that is an incompressible solver, but there was no negative pressure.
msrinath80 August 26, 2007 12:13
Perhaps by modifying the posit
Perhaps by modifying the position and/or the value of reference pressure in the lesInterFoam code. I think, the following line in pEqn.H does that:
pdEqn.setReference(pdRefCell, pdRefValue);
Check it out.
Alternately, an easier way would be to add a sufficiently large quantity to the entire phase pressure field after each time-step and calling this new variable something else (say pve_pd) and using this in your model. Bear in mind that I know nothing about cavitation modeling and I could very well be misleading you here. Please wait for a more experienced user to comment.
