Different dimensions for FATAL ERROR
Old   August 13, 2007, 17:33
Default Hi everyone, I trying to ru
Joseph F Slomski
retech is on a distinguished road
Hi everyone,
I trying to run an LES using oodles, with initial conditions mapped from a steady RANS solution gotten from simpleFoam. When I execute oodles, I get a curious error where oodles complains about "different dimensions". I've checked all of my object files to be sure I've got the dimensions OK, and couldn't find any mistakes there. (B/t/w, I'm trying to use the dynamic Smagorinsky SGS.) Part of the error message follows.
"Create mesh, no clear-out for time = 0
Reading field p
Reading field U
Selecting incompressible transport model Newtonian
Creating field Umean
Creating field R
Creating field Bmean
Creating field epsilonMean
Creating field pMean
Creating field pPrime2Mean
Starting time loop
Time = 5e-07
Courant Number mean: 0.00687179 max: 2.76796
[1]
[1]
[1] --> FOAM FATAL ERROR : Different dimensions for =
dimensions : [0 2 -1 0 0 0 0] = [0 1 0 0 0 0 0]
#0 Foam::error::printStack(Foam:stream&)
#1 Foam::error::abort()
#2 Foam::dimensionSet::operator=(Foam::dimensionSet const&) const
#3 Foam::GeometricField<double,>::operator=(Foam::tmp <foam::geometricfield<double,> > const&)
#4 Foam::LESmodels::dynSmagorinsky::correct(Foam::tmp <foam::geometricfield<foam::te nsor<double>, Foam::fvPatchField, Foam::volMesh> > const&)
#5 Foam::LESmodel::correct()
#6 main
#7 __libc_start_main
#8 __gxx_personality_v0 at ../sysdeps/x86_64/elf/start.S:116
[1]
[1]
[1] From function dimensionSet::operator=(const dimensionSet& ds) const
[1] in file dimensionSet/dimensionSet.C at line 156.
[1]
FOAM parallel run aborting..."
Any thoughts on what this is? I'm a VERY new Foam user, so not so much in Foam is obvious to me just yet ;)
Thanks,
Joe
retech is offline   Reply With Quote
Old   August 13, 2007, 18:22
Default Hi Joe, this message means re
frackowi
Hi Joe,
this message means really that some value is defined differently in your boundary conditions files and in the programm.
Have you checked the boundary files, whose dimension corresponds to [0 2 -1 0 0 0 0] ?
It could help for finding the bug, or at least which equation is concerned.
There is maybe an equation adimensionned by the velocity.
Old   August 14, 2007, 10:17
Default OK, that points me in the righ
Joseph F Slomski
OK, that points me in the right direction. I suspect my problem arises because I've mapped an incompressible RANS field, based on the k-w SST closure, into what I hope to be an incompressible LES field, based on the dynamic Smagorinsky sgs model.
In the RANS field, I specified BC files (and schemes/solvers) for k, nuTilda, omega, p, R, and U. For the LES field, I'm specifying BC files (and schemes/solvers) for B, k, nuSgs, nuTilda, p, and U.
So it would appear that the LES solver is looking for two fields with dimensions (0 2 -1 0 0 0 0), i.e., nuSgs and nuTilda, whereas the field mapped from the RANS solution only had one variable with that dimension, namely nuTilda.
So I think my question now is, how do I map the RANS field to the LES case while ensuring that the LES solver is getting the field it's looking for?
Joe
fatal error :(( ozgur CFX 0 August 30, 2008 20:09
fatal error hossein FLUENT 1 May 6, 2008 08:30
Fatal Error -- Help! Steve Roberts CFX 1 May 7, 2006 13:36
Fatal error error writing to tmp No space left on device maka OpenFOAM Installation 2 April 3, 2006 08:48
Fatal Error luiz eduardo bittencourt sampaio OpenFOAM Running, Solving & CFD 2 February 15, 2004 16:31
