Sloshing around plunging cylinder problem
Old   June 13, 2007, 16:53
Default Hi everybody, Inspired by t
Frank Bos
lr103476 is on a distinguished road
Hi everybody,
Inspired by the nice presentation given by Eric Paterson about waves and multi phase stuff, I tried also a nice example using interFoam, version 1.3.
It is my first experience with the interFoam solver, but I succeeded in solving the multiphase flow around a plunging cylinder. The boundary conditions are similar compared to the damBreak tutorial. So, walls left, right and lower, and on top atmosphere.
At first, the flow is nicely solved (although the mesh is coarse), which is illustrated in the following movie:
http://www.aero.lr.tudelft.nl/~frank...ngCylinder.avi
The most interesting observation is that the water level rises, which is rather strange. Has anyone any ideas how this is possible. Did I use improper boundary conditions, or is conservation not preserved when mesh motion is used in combination with interFoam. Why is the mesh motion removed from interFoam in the 1.4 release?
Regards, Frank
Frank Bos
lr103476 is offline   Reply With Quote
Old   June 13, 2007, 22:01
Default Might be the BC of alpha at th
liu
Xiaofeng Liu
liu is on a distinguished road
Might be the BC of alpha at the moving boundary.
Xiaofeng Liu, Ph.D., P.E.,
Assistant Professor
Department of Civil and Environmental Engineering
Penn State University
223B Sackett Building
University Park, PA 16802
Web: http://water.engr.psu.edu/liu/
liu is offline   Reply With Quote
Old   June 14, 2007, 03:16
Default What do you mean? gamma? I jus
Frank Bos
What do you mean? gamma? I just put gamma on the moving wall to be zeroGradient, like the other walls. pd is also set to zeroGradiet on this moving wall.
Furthermore, why is mesh motion removed from interFoam in the 1.4 release?
Regards, Frank
Frank Bos
Old   June 14, 2007, 10:24
Default I think the increase in water
Eugene de Villiers
eugene is on a distinguished road
I think the increase in water level is due to the waves at the zeroGradient boundary. Certainly you see the same kind of thing for a wavetank with a zeroGradient outlet alpha boundary. Again this is speculation, but I think the problem is akin to pressure floating in a domain with no fixed value pressure boundaries or cells.
eugene is offline   Reply With Quote
Old   June 14, 2007, 10:57
Default So what could be the correct B
liu
Xiaofeng Liu
So what could be the correct BC for gamma?
Assistant Professor
Old   June 14, 2007, 11:36
Default I'm not sure. And after some r
Eugene de Villiers
I'm not sure. And after some reflection, I don't think the wavetank example is related to Frank's problem.
Look at the gamma equation in 1.3:
ddt(gamma) + div(phi, gamma) + div(phiIR, gamma)
If both the fluxes phi and phiIR are zero on the boundary, then the total ammount of gamma should be preserved irrespective of the gamma boundary conditions.
phiIR however is a function of the surface curvature and for the moving mesh case, phi will be non-zero on the cylinder surface. I guess the easiest experiment would be to sum these two fluxes over all boundaries to figure out where the imbalance is coming from, i.e. calculate div(phi, gamma) and div(phiIR,gamma) as a global sum.
Old   June 14, 2007, 13:47
Default Frank, I'm glad my stuff mo
egp
egp's Avatar
Eric Paterson
egp is on a distinguished road
Frank,
I'm glad my stuff motivated you!
Concerning your problem, how did you set the top of your domain? I would use the Atmosphere b.c. (which sets the pressure), however, I would also make sure to move it much further away from the oscillating cylinder (maybe 5-10 diameters). I would set all of your side walls to noslip to make a case of a cylinder oscillating in a small tank of initially quiescent fluid.
Good luck, and keep us informed.
egp is offline   Reply With Quote
Old   August 12, 2007, 13:42
Default Frank, have you solved the inc
Yingfeng Shen
yingfeng is on a distinguished road
Frank, have you solved the increasing water level problem? I think I got the similar issue when I was trying to simulate a plane moving down towards a drop of water. The volume of the water is actually increasing even there is no wall contact with it yet. The observed gamma value can be much higher than 1.0. I guess this is related to mesh flux, or it might be that my boundary conditions are wrong somewhere. Here I enclose two pictures from paraFoam.
The version used is March foam1.3. I am interested to know your progress in the sloshingCylinder case.
Yingfeng
yingfeng is offline   Reply With Quote
Sloshing Problem in Rectangular Baffled tanks Prabodh FLUENT 1 September 27, 2013 13:27
Two phase-sloshing problem NARSIM FLUENT 1 July 30, 2011 05:35
help~~~sloshing problem using VOF shen FLUENT 0 November 6, 2007 07:08
HELP.......sloshing problem using VOF suryakant FLUENT 3 August 11, 2005 13:32
use of MAC method to solve sloshing problem. S.R.SAHI Main CFD Forum 1 April 15, 1999 22:28
