I am successfully (I think) ru
I am successfully (I think) running reactingFoam on a combustion problem. The write output timestep is 1e-05s, and the corresponding solution directories appear with all the field data. paraFoam shows the results and everything appears correct.
However, if I run the solution to say 1e-05s and stop, and then attempt to restart the solver by setting: startFrom startTime; startTime 1e-05; stopAt endTime; endTime 2e-05; deltaT 2.5e-06; writeControl adjustableRunTime; writeInterval 1e-05; in the <case>/system/controlDict file and re-running, it does nothing. The last few lines of output are: Constructing chemical mechanism Selecting ODE solver SIBS chemistryModel::chemistryModel: Number of species = 28 and reactions = 146 Courant Number mean: 2.59431e-08 max: 5.46438e-07 Starting time loop End Further, if I set startFrom to lastTime, it restarts at t=0, even though there is a valid 1e-05 solution folder. Has anyone else had this problem? |
