August 9, 2007, 06:30 |
I am successfully (I think) ru
Greg Collecutt
Rep Power: 17 |
I am successfully (I think) running reactingFoam on a combustion problem. The write output timestep is 1e-05s, and the corresponding solution directories appear with all the field data. paraFoam shows the results and everything appears correct.
However, if I run the solution to say 1e-05s and stop, and then attempt to restart the solver by setting: startFrom startTime; startTime 1e-05; stopAt endTime; endTime 2e-05; deltaT 2.5e-06; writeControl adjustableRunTime; writeInterval 1e-05; in the <case>/system/controlDict file and re-running, it does nothing. The last few lines of output are: Constructing chemical mechanism Selecting ODE solver SIBS chemistryModel::chemistryModel: Number of species = 28 and reactions = 146 Courant Number mean: 2.59431e-08 max: 5.46438e-07 Starting time loop End Further, if I set startFrom to lastTime, it restarts at t=0, even though there is a valid 1e-05 solution folder. Has anyone else had this problem? |
Display Modes | |
mvConvection in reactingFoam | smehdi609 | OpenFOAM Running, Solving & CFD | 7 | April 16, 2019 11:22 |
ReactingFoam | vassilis | OpenFOAM Running, Solving & CFD | 75 | September 11, 2013 16:22 |
Description of reactingFoam solver | panara | OpenFOAM | 17 | April 25, 2013 06:57 |
ReactingFoam solver | muthukaalai | OpenFOAM Running, Solving & CFD | 1 | June 16, 2008 14:36 |
ReactingFoam without reactions | lasb | OpenFOAM Running, Solving & CFD | 5 | June 10, 2008 09:50 |
