July 23, 2007, 11:11 |
Hello all!
I'm trying to do t
Dominique Turmel
Rep Power: 17 |
Hello all!
I'm trying to do topological changes in 2 directions of movement. I have modified movingConeTopoFvMesh to accept 2D movements, and everything is moving fine until layer addition or removal. For example, if the first layer addition is in the X axis, it is working ok, but at the second addition, in Z axis, it crashes (problems in addCellLayer.C). Has anybody ever tryed that before? And with success? Thanks a lot Dominique |
July 25, 2007, 16:51 |
I found...
We have, after eac
Dominique Turmel
Rep Power: 17 |
I found...
We have, after each layer additional or removal, rebuild every extrusion face and layer addition/removal interfaces. It is working if I do so... but still some problems with new cells having only 3 edges, according to foam... weird because it don't look so in paraview... |
Engine simulation with topological changes | marico | OpenFOAM Running, Solving & CFD | 12 | April 14, 2013 07:18 |
Mapping volsurface symmTensor fields after a topological change | jcmasters | OpenFOAM Bugs | 1 | September 4, 2007 13:48 |
Should I change to CFX ? | Raul | FLUENT | 1 | October 15, 2006 13:58 |
change in bc | PETE | Siemens | 0 | August 28, 2006 09:13 |
Air Change | Diogo Bolster | CFX | 3 | January 10, 2002 14:58 |
