I'll appreciate if someoen can
I'll appreciate if someoen can tell me what it takes to solve (implement) pressure-correction equation in OpenFOAM.
Sung-Eun,
Greetings!
If
Sung-Eun,
Greetings! If you haven't looked at it, this wiki might be helpful: http://openfoamwiki.net/index.php/IcoFoam One thing that you should be careful about, when you go changing the interior PISO loop is that the solution to the pressure equation is sensitive to the value of p as you declare pEqn, as the pre-existing p field is used for the explicit treatment of the non-orthoganality correction. |
Dave, how are you doing?
Ye
Yes, I've once read it. Nicely done! The reason I'm interested in the delta-form of presure equation is its potential benefits for some situations that I know from my experience with similar FV codes. I'm sorry that my question was probably too broad, which I think was why there has been little reponse. |
