Has anyone tried a delta form of pressure equation pressurecorrection equation with OpenFOAM |
July 18, 2007, 10:00 |
I'll appreciate if someoen can
Sung-Eun Kim
Rep Power: 17 |
I'll appreciate if someoen can tell me what it takes to solve (implement) pressure-correction equation in OpenFOAM.
July 23, 2007, 14:47 |
Sung-Eun,
Greetings!
If
David P. Schmidt
Rep Power: 17 |
Sung-Eun,
Greetings! If you haven't looked at it, this wiki might be helpful: http://openfoamwiki.net/index.php/IcoFoam One thing that you should be careful about, when you go changing the interior PISO loop is that the solution to the pressure equation is sensitive to the value of p as you declare pEqn, as the pre-existing p field is used for the explicit treatment of the non-orthoganality correction. |
July 24, 2007, 07:53 |
Dave, how are you doing?
Ye
Sung-Eun Kim
Rep Power: 17 |
Yes, I've once read it. Nicely done! The reason I'm interested in the delta-form of presure equation is its potential benefits for some situations that I know from my experience with similar FV codes. I'm sorry that my question was probably too broad, which I think was why there has been little reponse. |
OpenFOAM wonbt solve the momentum U equation | sek | OpenFOAM Running, Solving & CFD | 5 | March 6, 2008 16:27 |
Full navier stokes Equation descretized form | rawin | Main CFD Forum | 1 | September 21, 2005 12:42 |
Integral form of RANS equation | sandip | Main CFD Forum | 2 | October 5, 2004 07:31 |
Form of energy Equation | Newbie | FLUENT | 2 | March 9, 2004 07:16 |
Delta form of equations. | unknown | Main CFD Forum | 6 | March 8, 2004 07:46 |
