A Question for the Fluent Users
Old   July 23, 2007, 12:32
Default Hi, I want to know what is
lam
Hoang-Lam
lam is on a distinguished road
I want to know what is the criterium of convergence for a solver in Fluent which solves something like simpleFoam (incompressible flow).
Because I want to compare Fluent's criterium and my criterium that I used in simpleFoam.
Thanks in advance,
Lam
p.s: and can Fluent accept a model viscosity like BirdCarreau?
lam is offline   Reply With Quote
Old   July 23, 2007, 12:47
Default The standard convergence crite
Alberto Passalacqua
The standard convergence criteria adopted in FLUENT require that all residuals drop under 10^-3.
In my experience this requirement is not always satisfactory, especially for steady calculations. Usually I just set very low or zero residuals and check when residuals flatten and double-check convergence monitoring some property of the flow.
Yes, that viscosity model should already be implemented in FLUENT.
Regards,
A.
Alberto Passalacqua
Old   July 24, 2007, 05:00
Default Hi Alberto, Thanks for repl
lam
Hoang-Lam
Hi Alberto,
Thanks for replying me.
Do you think that a criterium which is somthing like:
norm[U_(n+1) - U_(n)]/norm[U_(n)] < tol
is wrong for a steady computations?
Otherwise, why this criterium is not implemented?
Old   July 24, 2007, 07:41
Default The residuals in FLUENT are de
sek
Sung-Eun Kim
sek is on a distinguished road
The residuals in FLUENT are defined as the errors of the discretized equations, i.e., a_P*U_P -{Sum (a_NB*U_NB) + S_U} i the case of U-momentum equation. They are often normalized (or scaled) by the factors of users' choice such as Sum(a_P*U_P}. I guess OPneFOAM uses the same definition.
sek is offline   Reply With Quote
Fluent users: I need your help! mimi FLUENT 0 May 8, 2007 03:55
Search Fluent Users in China Fred Kang FLUENT 5 August 26, 2003 04:53
Former Fluent Users Jan Rusås CFX 13 December 9, 2002 15:51
For Fluent and FieldView users Germain Lannegrand FLUENT 0 March 27, 2001 07:28
Help!!! Fluent 5.0 users! Jayanti Sinha Main CFD Forum 1 November 9, 1999 17:04
