July 11, 2007, 11:29 |
hi,
I am trying to get the
Oscar G
Rep Power: 17 |
hi,
I am trying to get the compilation of the laplacianFoam solver with wmake. But some errors happens. I type within $FOAM_APP/solvers/basic/laplacianFoam directory (OpenFOAM-1.4) simply 'wmake' but I have error messages like these: /home/oscar/OpenFOAM/linux/gcc-4.1.2/bin/../lib/gcc/i686-pc-linux-gnu/4.1.2/../. ./../../include/c++/4.1.2/bits/locale_facets.h:3916: error: variable or field '_M_initialize_moneypunct' declared void /home/oscar/OpenFOAM/linux/gcc-4.1.2/bin/../lib/gcc/i686-pc-linux-gnu/4.1.2/../. ./../../include/c++/4.1.2/bits/locale_facets.h:3916: error: 'int std::moneypunct<wchar_t,>::_M_initialize_moneypunc t' is not a static member of 'class std::moneypunct<wchar_t,>' /home/oscar/OpenFOAM/linux/gcc-4.1.2/bin/../lib/gcc/i686-pc-linux-gnu/4.1.2/../. ./../../include/c++/4.1.2/bits/locale_facets.h:3916: error: '__c_locale' was not declared in this scope /home/oscar/OpenFOAM/linux/gcc-4.1.2/bin/../lib/gcc/i686-pc-linux-gnu/4.1.2/../. ./../../include/c++/4.1.2/bits/locale_facets.h:3917: error: expected primary-expression before 'const' /home/oscar/OpenFOAM/linux/gcc-4.1.2/bin/../lib/gcc/i686-pc-linux-gnu/4.1.2/../. ./../../include/c++/4.1.2/bits/locale_facets.h:3917: error: initializer expression list treated as compound expression /home/oscar/OpenFOAM/linux/gcc-4.1.2/bin/../lib/gcc/i686-pc-linux-gnu/4.1.2/../. ./../../include/c++/4.1.2/bits/locale_facets.h:3921: error: variable or field '_M_initialize_moneypunct' declared void What's my mistake? Thanks! Oscar |
July 11, 2007, 12:26 |
Hi!
This is only a guess: i
Assistant Moderator
Bernhard Gschaider
Rep Power: 51 |
Hi!
This is only a guess: it looks like the compiler uses headers that he is not supposed to (for instance your sytem-g++ tries to use the OpenFOAM-g++-headers (but for some reason the OpenFOAM-g++ is not used)) Take the following steps: - Check which g++ you are using: 'which g++' - If it is not the OpenFOAM-g++ check the version with 'g++ -v' - Try to compile and execute a small helloWorld.C (you'll have to write one yourself) to check whether your compiler is working Bernhard PS: is this the first time you're trying to compile any OF-stuff on that machine?
Note: I don't use "Friend"-feature on this forum out of principle. Ah. And by the way: I'm not on Facebook either. So don't be offended if I don't accept your invitation/friend request |
July 11, 2007, 13:59 |
Hi Bernhard,
I have the fol
Oscar G
Rep Power: 17 |
Hi Bernhard,
I have the following messages: 1. 'which g++' -> /home/oscar/OpenFOAM/linux/gcc-4.1.2/bin/g++ 2. 'g++ -v' -> Using built-in specs. Target: i686-pc-linux-gnu Configured with: ../configure --prefix=/usr/tmp/gcc-4.1.2 --exec-prefix=/usr/tmp/gcc-4.1.2 --enable-languages=c,c++ --enable-shared --enable-__cxa_atexit --disable-checking Thread model: posix gcc version 4.1.2 3. With the compilation of 'HelloWorld.C' appears (gcc HelloWorld.C): helloworld.C:1:19: error with stdio.h helloworld.C:6:2: warning: no newline at end of file helloworld.C: In function 'int main()': helloworld.C:4: error: 'printf' was not declared in this scope You're right, the compiler isn't working. What can I do to fix this problem? Thanks! Oscar |
July 12, 2007, 09:48 |
Nope. You tried a C-HelloWorld
Assistant Moderator
Bernhard Gschaider
Rep Power: 51 |
Nope. You tried a C-HelloWorld. Try a C++-HelloWorld.
(although it looks like he doesn'T find standard-Headers. Check whether there are any under /home/oscar/OpenFOAM/linux/gcc-4.1.2/include (especially look for c++/4.1.2/bits/locale_facets.h) My guess: Something went wrong while unpacking the downloaded tar (not all the files reached the disk).
July 14, 2007, 15:53 |
hi,
I reviewed the archives
Oscar G
Rep Power: 17 |
hi,
I reviewed the archives of OpenFOAM installation in linux directory (gcc-4.1.2-, j2sdkl-1.4.2_05 and paraview-2.4.4), and they're all ok. About my compiler error messages I guess that are produce because the compiler installation in WM_PROJECT_INST_DIR/$WM_ARCH/gcc-3.4.? and enviroment variable in the $WM_PROJECT_DIR/.bashrc aren't correctly configured. I hope to fix it, I'd appreciate any suggestion . Thank you very much for your help. Oscar |
July 14, 2007, 15:57 |
hi,
I forgot it, this is t
Oscar G
Rep Power: 17 |
hi,
I forgot it, this is the first time trying to compile any OpenFoam solver on my machine. Thanks! Oscar |
July 18, 2007, 21:41 |
hi,
I could fix the errors.
Oscar G
Rep Power: 17 |
hi,
I could fix the errors. Thank you very much. The information about it in this link: > http://www.cfd-online.com/cgi-bin/Op...cus/discus.cgi Thanks! Oscar |
Display Modes | |
Problems in personal library compilation | shrina | OpenFOAM | 3 | February 23, 2009 11:12 |
UDF COMPILATION... | venkatesh4386@gmail.com | FLOW-3D | 0 | November 8, 2008 11:22 |
UDF compilation problems | MateuszZb | FLUENT | 4 | October 20, 2008 02:46 |
Compilation problems and file locations | Joel | Siemens | 3 | February 11, 2003 12:42 |
udf compilation | jy | FLUENT | 0 | August 10, 2000 09:39 |
