Home > Forums > OpenFOAM Running, Solving & CFD
InterFoam visualization
Old   July 11, 2007, 12:14
Default Consider a 3D rectangular chan
Srinath Madhavan (a.k.a pUl|)
msrinath80 is on a distinguished road
Consider a 3D rectangular channel of still water and at time t = 0 sec, a 3D air bubble rises from the bottom. The simulation completed nicely with interFoam. How can I visualize the bubble rising in water in paraView? Is there any way to separate cells based on density as opposed to gamma? I would prefer to see a sharp distinction. How do you postprocess 3D interFoam cases?
msrinath80 is offline   Reply With Quote
Old   July 11, 2007, 12:21
Default How about drawing an iso-surfa
Hrvoje Jasak
How about drawing an iso-surface of gamma = 0.5?
Hrv
Hrvoje Jasak
Old   July 11, 2007, 12:59
Default That did the trick. Thanks Hrv
That did the trick. Thanks Hrv! I suspect it was the same way you created that animation of air being injected from a tube into a water tank with a free surface.
Old   July 11, 2007, 14:03
Default Hrv: I thought you might want
Hrv: I thought you might want to look at a sample movie (two large diameter bubbles breaking up in a 3D tank completely filled with water) visualized using gamma isosurface = 0.5. I used OpenFOAM 1.4 and Bernhard's excellent funkySetFields utility to initialize gamma. Here it is:
http://www.ualberta.ca/~madhavan/isosurface_movie.mpg
Once again, thanks for your help
Thread Tools
Trackbacks are On
Visualization Bharath FLUENT 2 November 11, 2002 18:00
Need help on visualization Sujit Kirpekar Main CFD Forum 1 October 7, 2002 04:31
AMR Visualization Dawei Sun Main CFD Forum 1 June 27, 2002 01:12
CFD Visualization Chan Keen Ian Main CFD Forum 1 December 29, 2001 03:49
3d visualization Maciej Matyka Main CFD Forum 0 July 11, 2001 10:51
