I am just getting st
I am just getting started trying out OpenFOAM. I am using version 1.3, on Red Hat Enterprise 4. I am trying to compile just a trivial little .c file. I am seeing this error first thing when I type "wmake" : make: Warning: File `linuxGcc4DPOpt/objectFiles' has modification time 0.013 s in the future make: warning: Clock skew detected. Your build may be incomplete. make: Warning: File `Make/linuxGcc4DPOpt/dontIncludeDeps' has modification time 0.05 s in the future Making dependency list for source file firstSolver.c make: warning: Clock skew detected. Your build may be incomplete. My understanding is that this modified-in-the-future thing is a known issue with RHEL4, and I can't fix it. I thought I found a post in these forums about a way to alter how "tightly" wmake examined the modified timestamp, to give it more of a "window of acceptance," but I cannot find it now. Is this warning causing a problem? I have an enormous mass of errors after this make warning, but it seems possible they could all be caused by the make error. Thank you, |
hi,
i had similar problems
hi,
i had similar problems with an nfs-mounted file system - i guess your working with a non-local filesystem too? greetings stephan |
hi,
I am trying to get the
hi,
I am trying to get the compilation of the laplacianFoam solver with wmake. But some errors happens. I type within $FOAM_APP/solvers/basic/laplacianFoam directory (OpenFOAM-1.4) simply 'wmake' but I have error messages like these: /home/oscar/OpenFOAM/linux/gcc-4.1.2/bin/../lib/gcc/i686-pc-linux-gnu/4.1.2/../. ./../../include/c++/4.1.2/bits/locale_facets.h:3916: error: variable or field '_M_initialize_moneypunct' declared void /home/oscar/OpenFOAM/linux/gcc-4.1.2/bin/../lib/gcc/i686-pc-linux-gnu/4.1.2/../. ./../../include/c++/4.1.2/bits/locale_facets.h:3916: error: 'int std::moneypunct<wchar_t,>::_M_initialize_moneypunc t' is not a static member of 'class std::moneypunct<wchar_t,>' /home/oscar/OpenFOAM/linux/gcc-4.1.2/bin/../lib/gcc/i686-pc-linux-gnu/4.1.2/../. ./../../include/c++/4.1.2/bits/locale_facets.h:3916: error: '__c_locale' was not declared in this scope /home/oscar/OpenFOAM/linux/gcc-4.1.2/bin/../lib/gcc/i686-pc-linux-gnu/4.1.2/../. ./../../include/c++/4.1.2/bits/locale_facets.h:3917: error: expected primary-expression before 'const' /home/oscar/OpenFOAM/linux/gcc-4.1.2/bin/../lib/gcc/i686-pc-linux-gnu/4.1.2/../. ./../../include/c++/4.1.2/bits/locale_facets.h:3917: error: initializer expression list treated as compound expression /home/oscar/OpenFOAM/linux/gcc-4.1.2/bin/../lib/gcc/i686-pc-linux-gnu/4.1.2/../. ./../../include/c++/4.1.2/bits/locale_facets.h:3921: error: variable or field '_M_initialize_moneypunct' declared void What's my mistake? Thanks! Oscar |
