Ubar and Ubulk
Like Tree5Likes
  • 1 Post By hadi
  • 4 Post By maka
Old   July 4, 2007, 06:20
Default Hi to all Can u please tell
hadi tartoussi
hadi is on a distinguished road
Hi to all
Can u please tell me what is the difference betwwen Ubulk and Ubar (for a LES turbulent channel flow) and how to calculate it for a given Re-tau.
Thanks in advance
Hadi
Luttappy likes this.
hadi is offline   Reply With Quote
Old   July 4, 2007, 12:06
Default for the case of isothermal pla
Maka Mohu
maka is on a distinguished road
for the case of isothermal plane channel flow:
In literature, Ubulk usually is a volume averaged velocity which is a single number while, Ubar is usually an averaged (more accurately, an integral of) velocity (in time (after reaching fully developed flow and in homogeneous directions (x, z))), so it is a function of wall normal coordinate (Y); one can obtain Ubulk from Ubar by:
Ubulk=integral of (Ubar dy); where y is wall normal direction and Ubar is function of y;
have a look at postChannel utility;
If you are running your simulation by specifying Re_tau, then you are computing dimensionless variables. Try to derive the equations to be sure what are you doing. Have a nice day!
Best regards,
Maka.
maka is offline   Reply With Quote
Old   July 5, 2007, 08:52
Default Thanks alot for ur explanation
hadi tartoussi
Thanks alot for ur explanation.
But i am confused about Ubar in transportproperties (channelOodles solver) is it the centerline velocity? or bulk velocity?
Actually i ran postchannel for channel395 tutorial and i have the same problem as urs posted on Monday, December 11 2006: (PostChannel: collapsed field result inconsistancy)
can u please tell me how did u solve this problem?
Thanks in advance
regards
Hadi
Old   July 6, 2007, 07:44
Default Hi Hadi, Ubar is the bulk v
Maka Mohu
Hi Hadi,
Ubar is the bulk velocity. I posted the solution of the postChannel problem in the message that you referred to. Please recheck the message to read the solution.
Best regards,
Maka
