difference between inletValue and value in inletOutlet B.C. |
May 29, 2011, 07:34 |
Dear foamers
I try to run a case and have a problem with inletOutlet Boundary condition. What is the difference between the inletValue and value in this B.C.? It seems that they have a same value in most of the cases. regards, Moha |
May 29, 2011, 10:31 |
inletOutlet is a back flow boundary condition for outlet. If fluid attepts to flow inwards, it applies a fixed value velocity assigned by inletValue for that given patch face. Or, it use zerogradient.
InletValue is the value flow inwards you have to give. value is the actual value for the given patch. given by inletValue or patchface neighbour cell(zerogradient). Hope this helps. regards, Junwei |
May 29, 2011, 22:43 |
Thanks for your answer. It was useful for me.
May 30, 2011, 13:28 |
#4 | |
Santiago Marquez Damian
Rep Power: 23 |
Junwei, your explanation about inletValue is clear for me but the one for value isn't.
Regards.
Santiago MÁRQUEZ DAMIÁN, Ph.D. Research Scientist Research Center for Computational Methods (CIMEC) - CONICET/UNL Tel: 54-342-4511594 Int. 7032 Colectora Ruta Nac. 168 / Paraje El Pozo (3000) Santa Fe - Argentina. http://www.cimec.org.ar |
May 30, 2011, 21:01 |
value is a keyword for all the numerical boundary condition. It is not used for input but calculated based on the boundary you set. It is useful for postprocessing. you can set the same value as inletValue, and it will be updated during the calculation.
sometimes, paraview don't like boundary condition without "value" entry. Regards, Junwei |
May 30, 2011, 21:42 |
Rep Power: 23 |
Junwei, thanks for the clarification and confirmation. Tthat's true when values are calculated "value" entry data is replaced by which is calculated at running time.
Regards.
