June 22, 2007, 16:26 |
Any idea what's wrong?
I've m
Dominique Turmel
I've modified MovingConeTopoFvMesh to account for 2D motion. I now have 4 layer addition/removal interfaces. It is working fine for 1D movement, in X or in Z, but when I try to have both working at the same time, I have troubles like that! Inserted untouched faces into cells Inserted modified faces into cells Inserted added faces into cells Added internal faces. Face count = 68594 Patch 0: added faces: untouched = 240 modified = 0 added = 0. Face count = 68834 Patch 1: added faces: untouched = 240 modified = 0 added = 0. Face count = 69074 Patch 2: added faces: untouched = 1485 modified = 15 added = 0. Face count = 70574 Patch 3: added faces: untouched = 1584 modified = 17 added = 0. Face count = 72175 Patch 4: added faces: untouched = 1485 modified = 15 added = 0. Face count = 73675 Patch 5: added faces: untouched = 1584 modified = 17 added = 0. Face count = 75276 #0 Foam::error::printStack(Foam:stream&) #1 Foam::sigSegv::sigSegvHandler(int) #2 Uninterpreted: [0xf72420] #3 cfree #4 operator delete(void*) #5 operator delete[](void*) #6 Foam::List<int>::operator=(Foam::List<int> const&) #7 Foam::polyTopoChanger::changeMesh(Foam::polyMesh&, Foam::polyTopoChange const&) #8 Foam::polyTopoChanger::changeMesh() #9 Foam::movingWallTopoFvMesh::update() #10 main #11 __libc_start_main #12 Foam::regIOobject::readIfModified() Erreur de segmentation Or : bool layerAdditionRemoval::changeTopology() const for object up : Layer thickness: min: 1.105 max: 1.105 avg: 1.105 old thickness: 1.1 Removal threshold: 0.2 addition threshold: 1.1 bool layerAdditionRemoval::changeTopology() const for object up : Triggering layer addition Modifier 0 named up morphing bool layerAdditionRemoval::changeTopology() const for object down : Layer thickness: min: 0.865 max: 0.865 avg: 0.865 old thickness: 0.87 Removal threshold: 0.2 addition threshold: 1.1 Modifier 1 named down unchanged bool layerAdditionRemoval::changeTopology() const for object left : Layer thickness: min: 0.075 max: 0.075 avg: 0.075 old thickness: 0.07 Removal threshold: 2 addition threshold: 5 Modifier 2 named left unchanged bool layerAdditionRemoval::changeTopology() const for object right : Layer thickness: min: 4.865 max: 4.865 avg: 4.865 old thickness: 4.87 Removal threshold: 2 addition threshold: 5 Modifier 3 named right unchanged void layerAdditionRemoval::addCellLayer(polyTopoChange& ref) const for object up : Adding cell layer void layerAdditionRemoval::addCellLayer(polyTopoChange& ref) const for object up : Using edges for point insertion --> FOAM FATAL ERROR : Cannot find patch for edge 27812. Edge: (8955 8961)#0 Foam::error::printStack(Foam:stream&) #1 Foam::error::abort() #2 Foam::layerAdditionRemoval::addCellLayer(Foam::pol yTopoChange&) const #3 Foam::layerAdditionRemoval::setRefinement(Foam::po lyTopoChange&) const #4 Foam::polyTopoChanger::topoChangeRequest() const #5 Foam::polyTopoChanger::changeMesh() #6 Foam::movingWallTopoFvMesh::update() #7 main #8 __libc_start_main #9 Foam::regIOobject::readIfModified() From function void Foam::layerAdditionRemoval::setRefinement(polyTopo Change& ref) in file layerAdditionRemoval/addCellLayer.C at line 391. FOAM aborting Abandon Any hints or ideas? Thanks a lot! Dominique |
How to change Prt | Gu Hanyang | CFX | 0 | September 28, 2008 14:28 |
Should I change to CFX ? | Raul | FLUENT | 1 | October 15, 2006 13:58 |
Looking for a change. | Sunil | Main CFD Forum | 0 | May 9, 2006 09:50 |
Change BC during the run? | jx | FLUENT | 7 | November 6, 2003 20:45 |
change the | Junyan | FLUENT | 0 | July 2, 2002 02:46 |
