SIMPLE algorithm details
Old   June 20, 2007, 09:14
Default Hi all, In simpleFoam.C, fo
lam
Hoang-Lam
lam is on a distinguished road
Hi all,
In simpleFoam.C, for example,
I do not understand :
1/ What "adjustPhi(phi,U,p)" does?
Can somebody summarize me quickly what it's done?
2/ According to the simple algo, I understand that the momentum equation is solved first, by guessing p. But when the boundary conditions for U are involved ?
And
i/ What does "p.boundaryField().updateCoeffs();"mean?
ii/ Or "U.correctBoundaryConditions();"?
Can somebody tell me where I have to look harder?
Thanks in advance,
Lam
lam is offline   Reply With Quote
Old   June 21, 2007, 04:50
Default Short answer for where you sho
Fabian Peng Karrholm
fabianpk is on a distinguished road
Short answer for where you should look harder is the source code. However, a more pleasant read (no offense) would probably be:
http://openfoamwiki.net/index.php/IcoFoam
even though it's transient, adjustPhi etc are the same.
fabianpk is offline   Reply With Quote
Old   June 21, 2007, 05:07
Default I wrote these some time ago to
Alberto Passalacqua
I wrote these some time ago too:
http://openfoamwiki.net/index.php/Th...hm_in_OpenFOAM
Regards,
Alberto
Alberto Passalacqua
Old   June 21, 2007, 10:14
Default Hi guys, I just follow your
lam
Hoang-Lam
Hi guys,
I just follow your advice.
Moreover, I had taken a look harder in the source code of "adjustPhi"
I understand that
adjustPhi(phi,U,p) keeps the continuity of the system, doesn't it?
I mean for each face, the inlet flux = the outlet flux.
So, in a discretized form: Sum[U_f * S_f] = 0.
This what I understood for "adjustPhi".
Hope that you will tell me if I'm wrong.
But I still seek where the boundayconditions are involved.
Cheers,
Lam
SIMPLE algorithm su Main CFD Forum 3 August 14, 2008 16:58
About Phase Coupled SIMPLE (PC-SIMPLE) algorithm Yan Kai Main CFD Forum 0 April 18, 2007 03:48
About Phase Coupled SIMPLE (PC-SIMPLE) algorithm Yan Kai FLUENT 0 April 13, 2007 23:17
SIMPLE Algorithm shreya Main CFD Forum 3 February 22, 2004 05:54
SIMPLE Algorithm littlelz Main CFD Forum 2 April 11, 2003 20:25
