-   -   Obtain PointLabels from code (http://www.cfd-online.com/Forums/openfoam-solving/59629-obtain-pointlabels-code.html)
bfa June 19, 2007 11:27
Hello out there, I need two
Hello out there,
I need two things to be done, and somehow don't manage to do it:
1) How can I get the ID of a patch by name (I tried findPatchID, but it doesn't work on a fvMesh)?
2) How can I get the labels of the points belonging to this patch?
by the way: the search function in my doxygen representation is broken and it's quite hard to guess the right class if i want to find a specific function. Is that a known issue or am I alone with this problem?
thanks for your guidance
Bjoern
fra76 June 19, 2007 11:50
Hi Björn! The answer to the f
Hi Björn!
The answer to the first question should be:
label patchI = mesh.boundaryMesh().findPatchID("patchname");
Regarding the second question, I don't know exactly how to access the point, but with this line you can access the faces centers:
const fvPatchVectorField& faceCentres = mesh.Cf().boundaryField()[patchID];
For the point, perhaps something like:
const fvPatchVectorField& faceCentres = mesh.points().boundaryField()[patchID];
But I've never tried it...
eugene June 19, 2007 12:09
You can get all the point labe
You can get all the point labels on a patch via:
const labelList listOfPatchPointLabels mesh.boundaryMesh()[patchID].meshPoints();
Check:
src/OpenFOAM/lnInclude/PrimitivePatch.H and polyPatch.H for the members of polyPatch (i.e. mesh.boundaryMesh()[patchID]).
bfa June 19, 2007 13:08
thanks a lot to both of you!
it worked just fine
alberto June 19, 2007 14:25
The search function in the dox
The search function in the doxygen documentation requires you install the documentation on a web server with php enabled.
Regards,
Alberto
