Home > Forums > OpenFOAM Running, Solving & CFD
Why to say OF uses %e2%80%98Pseudostaggered%e2%80%99 finite volume numerics
Like Tree6Likes
  • 3 Post By hjasak
  • 1 Post By hjasak
  • 2 Post By henry
Old   August 30, 2005, 20:30
Default Hi all FOAMers, On OpenCFD we
Leosding
leosding is on a distinguished road
Hi all FOAMers,
On OpenCFD web:
To maintain generality and solve complex on real 3D cases, OpenFOAM uses
'Pseudo-staggered' finite volume numerics
but I can not find out from source.
Would somebody give me some help for understanding it?
Thanks in advance!
Leo
leosding is offline   Reply With Quote
Old   August 30, 2005, 21:09
Default It means that the velocity fie
Hrvoje Jasak
It means that the velocity field in the algorithm is treated as passive and instead of solving transport equations for it you recover it from the flux field (which caries the same information). That would be the:
U += rUA*fvc::reconstruct((phi - phiU)/rUAf);
bit in the pressure equation of interFoam;
Hrv
Hrvoje Jasak
Old   August 30, 2005, 21:44
Default But in application simpleFoam
Leosding
But in application simpleFoam you solve the UEqn with
"solve(UEqu()++-fvc::grad(p));"
but I find the solution of UEqn --velocity field-- isn't used in following steps(if my understanding is right.), only use the UEqu.A() and UEqn.H() from UEqn assembling fvVectormatrix, then why solve the UEqu?
Leo
Old   August 30, 2005, 21:46
Default sorry, type erro. Should be "
Leosding
"solve(UEqu()==-fvc::grad(p));"
Leo
Old   August 30, 2005, 22:11
Default Hehe, how about: U = rUA*U
Hrvoje Jasak
Hehe, how about:
U = rUA*UEqn.H();
We said before in this forum that the H() operator uses the current solution to do a Jacobi sweep:
In Hoperations.C
// H operator
template<class>
tmp<field<type> > lduMatrix::H(const Field<type>& sf) const
tmp<field<type> > tHphi
new Field<type>(lduAddr_.size(), pTraits<type>::zero)
if (lowerPtr_ || upperPtr_)
Field<type> & Hphi = tHphi();
const scalarField& Lower = lower();
const scalarField& Upper = upper();
// Take refereces to addressing
const unallocLabelList& l = lduAddr_.lowerAddr();
const unallocLabelList& u = lduAddr_.upperAddr();
for (register label face=0; face<l.size(); face++)
Hphi[u[face]] -= Lower[face]*sf[l[face]]; <--- right there!
Hphi[l[face]] -= Upper[face]*sf[u[face]];
return tHphi;
and then called in fvMatrix.C
tHphi().internalField() += lduMatrix::H(psi_.internalField()) + source_;
Hrv
mm.abdollahzadeh likes this.
Hrvoje Jasak
Old   August 30, 2005, 22:18
Default I get it. Thanks a lot!
Leosding
I get it.
Thanks a lot!
Old   August 31, 2005, 03:13
Default In addition to the reconstruct
henry is on a distinguished road
In addition to the reconstruct method to convert the staggered pressure gradient and "drag" terms into cell centered versions for the momentum corrector I have also introduced the ddtPhiCorr method to replace the cell-centered rate-of-change with the face-based flux version in the flux predictor making the solution for the fluxes not only staggered with respect to the pressure gradient and "drag" terms but also staggered with respect to the rate-of-change. Test solutions of the simplified shallow-water equations have shown that this formulation is equivalent to the Arakawa and Lamb C-grid staggering.
mm.abdollahzadeh and hua1015 like this.
henry is offline   Reply With Quote
Old   June 14, 2007, 13:51
Default Sorry if I came late to this d
diablo80@web.de
sampaio is on a distinguished road
Sorry if I came late to this discussion, but I still dont get it...
If I set
U = rUA*UEqn.H();
isnt the U previously calculated in
if (momentumPredictor)
solve(UEqn == -fvc::grad(p));
lost anyway?
What is the point of checking "momentumPredictor" if the value of U will be lost anyway inside PISO loop (U = rUA*UEqn.H())?
I feel my understanding of OF is still very poor, so I am sorry for this stupid question...
Best regards,
luiz
sampaio is offline   Reply With Quote
Old   June 14, 2007, 16:15
Default Sorry, of course U = rUA*UEqn.
diablo80@web.de
Sorry, of course U = rUA*UEqn.H() scope was limited to PISO loop by the brackets and would not affect the solved momentum equation.
Sorry for that...
Thread Tools
Trackbacks are On
sliding mesh with Finite elements or finite volume tool Main CFD Forum 0 October 9, 2008 10:07
formulation of finite element&finite volume method ravindra FLUENT 0 June 27, 2007 12:04
finite elemte VS finite volume ztdep Main CFD Forum 4 April 13, 2006 07:43
Finite Element vs. Finite Volume Codes Salman Main CFD Forum 9 January 6, 2006 23:59
Finite volume or finite differene for free surface G N Xie Main CFD Forum 8 January 10, 2005 08:42
