-   -   Problems after installing 14 and trying to build my solver (http://www.cfd-online.com/Forums/openfoam-solving/59638-problems-after-installing-14-trying-build-my-solver.html)
alan_fergus June 11, 2007 10:26
i getting the following errors
i getting the following errors when i try to make my solver on 1.4, had no of these problems with 1.2. and i was wondering if anyone could give me some insight in how to fix the problem
the error is as follows
SOURCE=IncompressibleCloud.C ; g++ -m32 -Dlinux -DDP -Wall -Wno-strict-aliasing -Wextra -Wno-unused-parameter -Wold-style-cast -O3 -DNoRepository -ftemplate-depth-40 -I/home/alan/OpenFOAM/OpenFOAM-1.4/src/cfdTools/incompressible -I/home/alan/OpenFOAM/OpenFOAM-1.4/src/OpenFOAM/lnInclude -I/home/alan/OpenFOAM/OpenFOAM-1.4/src/lagrangian/basic/lnInclude -I/home/alan/OpenFOAM/OpenFOAM-1.4/src/cfdTools/general/lnInclude -I/home/alan/OpenFOAM/OpenFOAM-1.4/src/finiteVolume/lnInclude -IlnInclude -I. -I/home/alan/OpenFOAM/OpenFOAM-1.4/src/OpenFOAM/lnInclude -fPIC -pthread -c $SOURCE -o Make/linuxGcc4DPOpt/IncompressibleCloud.o
/home/alan/OpenFOAM/OpenFOAM-1.4/src/finiteVolume/lnInclude/volPointInterpolatio n.H: In constructor 'Foam::IncompressibleCloud::IncompressibleCloud(co nst Foam::volPointInterpolation&, const Foam::volVectorField&)':
/home/alan/OpenFOAM/OpenFOAM-1.4/src/finiteVolume/lnInclude/volPointInterpolatio n.H:70: error: 'Foam::volPointInterpolation::volPointInterpolatio n(const Foam::volPointInterpolation&)' is private
IncompressibleCloud.C:86: error: within this context
IncompressibleCloud.C: In member function 'void Foam::IncompressibleCloud::track()':
IncompressibleCloud.C:176: error: 'track' is not a member of 'Foam::Cloud<foam::hardballparticle>'
make: *** [Make/linuxGcc4DPOpt/IncompressibleCloud.o] Error 1
msrinath80 June 11, 2007 16:32
Many things changed from 1.2 t
Many things changed from 1.2 to 1.3. For instance, cfdTools was replaced by finiteVolume and so on. Check the wiki[1].
[1] http://openfoamwiki.net/index.php/Ho...versions_to_13
alberto June 14, 2007 04:24
I would add that the lagrangia
I would add that the lagrangian classes have been changed too in OF 1.4.
A.
