June 11, 2007, 06:39 |
Hi all,
I need to know if a
Hoang-Lam
Rep Power: 17 |
Hi all,
I need to know if anybody has already implemented a simple Stockes equation? (without the non-linear term) Lam |
June 11, 2007, 16:34 |
Check out potentialFoam.
An
Srinath Madhavan (a.k.a pUl|)
Rep Power: 21 |
Another related discussion thread: http://www.cfd-online.com/OpenFOAM_D...es/1/2765.html |
June 11, 2007, 16:45 |
My Apologies. potentialFoam is
Rep Power: 21 |
My Apologies. potentialFoam is the opposite of what you want. Check that other thread instead.
June 12, 2007, 03:22 |
Hi pUIl,
Thank you to reply
Hoang-Lam
Rep Power: 17 |
Hi pUIl,
Thank you to reply me. Indeed, I think taht I found how to have a simple Stockes: I removed "div(phi,U)" term in the simpleFoam. Of course, I made it after studying precisely the code with DoxyGen. I'm quite sure that I have my STOCKES solver, now. Hope that somebody does tell me if I'm wrong. Cheers, Lam |
June 12, 2007, 03:28 |
Do a quick validation. Stokesi
Rep Power: 21 |
Do a quick validation. Stokesian flow past a fixed sphere. There are analytical expressions you can compare your numerical results with.
June 12, 2007, 05:42 |
Hi pUII,
Thnaks to give thi
Hoang-Lam
Rep Power: 17 |
Hi pUII,
Thnaks to give this information. I've tried to find the ananlytical expression but I've not found it. Can you tell in which paper I can find it? THanks in advance pUII, Lam |
June 12, 2007, 05:50 |
Compare your velocity/pressure
Rep Power: 21 |
Compare your velocity/pressure fields with any of the analytical expressions[1,2]. Alternately, you could try using the liftDrag utility to estimate the net drag force on the sphere and compare it with the usual expression:
Fd = 6 * pi * dynamic viscosity * radius * free_stream_velocity [1] http://scienceworld.wolfram.com/phys...lowSphere.html [2] http://web.mit.edu/fluids-modules/ww.../2-5Stokes.pdf |
June 12, 2007, 08:38 |
Ok, pUII!
I think this the
Hoang-Lam
Rep Power: 17 |
Ok, pUII!
I think this the right way to check. Thanks again. My best cheers, Lam |
Display Modes | |
FoamUser and steady STOCKES | Lam | Main CFD Forum | 0 | June 8, 2007 04:20 |
