Home > Forums > OpenFOAM Running, Solving & CFD
Dieselspray in Parallel
Old   June 11, 2007, 04:36
Default As I understood it from the Za
Fabian Peng Karrholm
fabianpk is on a distinguished road
As I understood it from the Zagreb meeting, there's some interest in how solvers perform in parallel. Since I did some limited testing on our cluster I thought I'd post the speedup rates here. First a description of the cluster:
252 nodes of
4 Xeon 5160 (Woodcrest) 3 GHz cores (dual dual core)
MPI over gigbit etehernt
The case:
64k cells, hex-mesh, about 10x10x10 cm^3 size
Conditions are above autoignition conditions, so it starts to react rather quickly.
Chemistry mechanism of 250+ reactions, 60+ species,
injection speed is 700 m/s
Courant number of 0.1, nCorrectors=3, residuals at 1e-6, limitedLinear for most div-terms, Euler in time
I've run it for 1 hour on 4 processors (which is only on one node and doesn't require network except for file access), 8 and 12 processors.
So results normalised to the 4 processor case:
processors: 4 8 12
speedup: 4 7.3404 10.5819
Come to think of it, this isn't really a test of the lagrangian particles in parallel, as it's only max 50 parcels, and they are most likely always on just one processor (the one closest to the injector). I used a metis decomposition.
If I have time I'll run some of any of the tutorials but with a finer mesh, so it's easier to compare.
fabianpk is offline   Reply With Quote
Thread Tools
Trackbacks are On
Parallel pi FLUENT 1 December 25, 2008 13:46
parallel CCM+ tom CD-adapco 5 May 8, 2008 18:54
Parallel UDF Karo FLUENT 1 April 24, 2008 08:38
Parallel UDF ccc FLUENT 0 December 3, 2004 23:17
CFX-5.5 Parallel NT Kawena CFX 4 March 13, 2002 21:24
