Problems with channelOodles tutorial
Old   June 5, 2007, 09:08
Default If you run channelOodles tutor
Alberto Passalacqua
If you run channelOodles tutorial and then postprocess it with postChannel, you obtain a correct u.xy and uv.xy, but the data in v.xy and w.xy are oscillating.
Running the same case with OF 1.3 and using the 1.3 tool worked OK, but it's not easy to cross-check because OF 1.4 uses volSymmTensor while 1.3 doesn't.
It seems a post-processing issue, but the only difference I found during my quick check to the postChannel tool is in the use of the volSymmTensorField for R.
Any idea?
Thanks in advance,
Alberto
Alberto Passalacqua
Error in channelOodles tutorial alberto OpenFOAM Bugs 62 June 8, 2010 07:13
ChannelOodles maka OpenFOAM Bugs 12 February 5, 2009 18:17
GradP in channeloodles nikos_fb16 OpenFOAM Running, Solving & CFD 1 September 4, 2007 10:52
ChannelOodles in parallel maka OpenFOAM Bugs 3 August 21, 2007 17:30
[OpenFOAM] Error while postprocessing channelOodles tutorial in OpenFOAM 13 alberto ParaView 4 April 13, 2006 05:58
