Writing additionnal output files during a run
Old   May 23, 2007, 13:53
Default Hi everyone, I am running t
laurent glasson
laurentgla is on a distinguished road
Hi everyone,
I am running turbFOAM with a k-e turbulence model and wanted to see the evolutions of the Reynolds stresses during the calculation.
So I was looking for a way to write a R file for each step next to U, k, epsilon, etc... But I'm a bit lost and don't know where to start.
Where is the part of code stipulating which output has to be written down?
Thank you in advance
Laurent
laurentgla is offline   Reply With Quote
Old   May 23, 2007, 14:05
Default mkDir(runTime.path()/"xyz");
liu
Xiaofeng Liu
liu is on a distinguished road
OFstream logFile(runTime.path()/"xyz"/"myLog.dat");
logFile << bla bla bla << endl;
Xiaofeng Liu, Ph.D., P.E.,
Assistant Professor
Department of Civil and Environmental Engineering
Penn State University
223B Sackett Building
University Park, PA 16802
Web: http://water.engr.psu.edu/liu/
liu is offline   Reply With Quote
Old   May 23, 2007, 14:07
Default Reynolds stress never gets cal
Eugene de Villiers
eugene is on a distinguished road
Reynolds stress never gets calculated, it there is no option to write it out.
The divergence or R does get calculated, but it is a temporary field and does not exist for most of the calculation.
If you want to write out R, you first have to create the R field in createFields after the turbulence model has been constructed:
volVectorField R
IOobject
"R",
runTime.timeName(),
mesh,
IOobject::NO_READ,
IOobject::AUTO_WRITE
turbulence().R()()
Then you have to update it after each loop:
R = turbulence().R()();
calculate it using the turbulence().R()() function call.
It will write out automatically.
eugene is offline   Reply With Quote
Old   May 25, 2007, 10:35
Default thanks very much for your mess
laurent glasson
thanks very much for your messages. It now works after some minor tuning.
laurent
Writing forces to text files christian OpenFOAM Running, Solving & CFD 1 March 19, 2011 23:20
Writing geometry files in STAR-CD Sachin Siemens 5 April 22, 2008 16:38
Error in browse additionnal output file student Siemens 2 August 9, 2006 05:18
Pb with writing the Case and Dat files Sam FLUENT 2 May 14, 2004 11:16
Writing grid and velocity data to files Mehul Kinariwala FLUENT 2 October 4, 2000 09:26
