February 27, 2007, 03:15 |
hello,
when I start a simul
marc de boer
hello,
when I start a simulation (for example the cavity case) only 'solving for p' is reported with some other info, but I am missing 'solving for U' or so. With an other case in simpleFoam still only 'solving for p' is reported. U, k, epsilon etc. are missing...does anybody know why and if it matters? thanks, Marc |
April 10, 2007, 19:31 |
OK this is ridiculous. I have
Srinath Madhavan (a.k.a pUl|)
Rep Power: 21 |
OK this is ridiculous. I have the same problem on one case and all others run fine. In fact I know that the velocities are getting computed as I find the saved results in the time-directory.
I have included the entire simpleFoam case. Can someone try it on their machine and report whether velocity calculations are printed in the log file? Thanks! The case can be found here: http://www.ualberta.ca/~madhavan/sample.tar.gz |
April 12, 2007, 18:19 |
Hi pUI,
can you report this
Mattijs Janssens
Rep Power: 26 |
Hi pUI,
can you report this as a bug? |
April 12, 2007, 18:59 |
Will do Mattijs. Thanks.
Rep Power: 21 |
reported mass flow differs from monitored mass flo | London | FLUENT | 4 | July 17, 2008 12:44 |
Problematic geometry reported | smillerhh | FLUENT | 1 | December 7, 2006 11:42 |
