March 23, 2007, 06:06 |
Hi Rafal,
As you said to me
Hoang-Lam
Rep Power: 17 |
Hi Rafal,
As you said to me it was possible, I create my own equation in Foam. In icoFoam.C, I moved the Navier-Stokes equation for a another eqution easier: nu*Laplacien(U)=Grad(p) In th eicoFoam.C, I wrote this line below: ******************************************** fvVectorMatrix UEqn ( fvm::laplacian(nu, U) ); solve(UEqn == fvc::grad(p)); ********************************************** And I changed anything else, in any files (of course, I made the ./Allmake) But I had a wrong solution, when did: icoFoam SFOAM_RUN/tutorials/icoFoam MyCavity (MyCavity is a case that I created, diferent from the "cavity" case). My solution is actually: ************************************************ Time = 0.01 Mean and max Courant Numbers = nan nan ICCG: Solving for Ux: solution singularity ICCG: Solving for Uy: solution singularity ICCG: Solving for Uz: solution singularity ICCG: Solving for p: solution singularity time step continuity errors : sum local = nan, global = nan, cumulative = nan ICCG: Solving for p: solution singularity time step continuity errors : sum local = nan, global = nan, cumulative = nan ExecutionTime = 0.75 s ClockTime = 1 s ************************************************ I know there is somethin wrong with the timeStep here. But I do not know what and where I have to cahnge things to solve my problem! Can you, or someboby else, give me some advice? Thanks in advance, Lam |
March 23, 2007, 06:36 |
Hi Lam,
there can be many c
rafal zietara
Rep Power: 17 |
Hi Lam,
there can be many causes of solution singularity. Several thing that I can see here. - you removed time derivative and you try to solve something in time(maybe start with different solver for steady state ie simpleFoam) - the equation now is diagonally equal (since diffusion term produce diagonally equal matrix; grad(p) is source term) and matrix has to be diagonally dominant to solve it. these are my quick ideas (i can be wrong) rafal |
March 23, 2007, 07:30 |
Thamks Rafal to reply me,
I
Hoang-Lam
Rep Power: 17 |
I'm thinkin about your ideas. Regards, Lam |
March 28, 2007, 06:04 |
Hi world!
I did a big mista
Hoang-Lam
Rep Power: 17 |
Hi world!
I did a big mistake, I delete by accident my doc/Doxygen/html!! How can I get it again??? Thanks in advance, Lam |
March 28, 2007, 06:21 |
you can untar OF project in OT
rafal zietara
Rep Power: 17 |
you can untar OF project in OTHER directory
than ~/OpenFOAM. and than move it to right place: i.e: $ mkdir other $ cd other $ tar -xzf /path/to/OpenFoam-1.3.General.tgz #not sure of name here $ mv other/OpenFOAM-1.3/doc/Doxygen ~/OpenFOAM/OpenFOAM-1.3/doc $ cd .. $ rm -rf other this should work rafal |
March 28, 2007, 09:35 |
Oki, Rafal!
You're right!
Hoang-Lam
Rep Power: 17 |
Oki, Rafal!
You're right! Thanks a lot! Lam |
March 29, 2007, 07:30 |
Hi world,
I'm wondering mys
Hoang-Lam
Rep Power: 17 |
Hi world,
I'm wondering myself again about simpleFoam.C I noticed that I could put the turbulence in "off": but what kind of equation will I solve as result? Somebody can help me? Thanks in advance, Lam |
March 30, 2007, 03:37 |
HEY, everyone!
Nobody can g
Hoang-Lam
Rep Power: 17 |
HEY, everyone!
Nobody can give me some advice? Cheers, LAm |
How to solve equation ∂^2U/∂X^2 +∂^2U/∂Y^2 | V.Gnanaraj | Main CFD Forum | 3 | May 31, 2008 14:08 |
Can someone tell me how to solve this equation! | Guangli | Main CFD Forum | 2 | March 29, 2006 00:51 |
how can solve this equation | Jianfeng Xia | Main CFD Forum | 9 | April 10, 2005 19:26 |
how to solve an equation at an interface | sreenivas | CFX | 0 | May 14, 2004 09:35 |
How to solve Poisson equation in CFX 4? | windhair | CFX | 3 | January 27, 2004 21:09 |
