Axisymmetric opposed jet configuration
Old   March 20, 2007, 08:39
Default Hi all, I am new to OF so m
gianfilippo coppola
gfcoppola is on a distinguished road
I am new to OF so my question may be stupid, anyway, I am trying to simulate an axisymmetric opposed jet configuration, where each jet has a circular flange flat with the exit section. I am using icoFoam from FoamX and blockMesh to generate the mesh. Below is the blockMeshDict file:
arguments "/$HOME/OpenFOAM/$HOME-1.3/run/tutorials/icoFoam/counterflow" off;
convertToMeters 0.001;
vertices
(-14.5852 0 0)
(-0.297656 0 0)
(-0.297656 1.19063 -0.051984)
(-14.5852 1.19063 -0.051984)
(0.297656 0 0)
(0.297656 1.19063 -0.051984)
(14.5852 0 0)
(14.5852 1.19063 -0.051984)
(0.297656 100 -4.366094)
(-0.297656 100 -4.366094)
(-0.297656 1.19063 0.051984)
(-14.5852 1.19063 0.051984)
(0.297656 1.19063 0.051984)
(14.5852 1.19063 0.051984)
(0.297656 100 4.366094)
(-0.297656 100 4.366094)
blocks
hex (0 1 2 3 0 1 10 11) (39 20 1) simpleGrading (0.04 0.3 1)
hex (1 4 5 2 1 4 12 10) (10 20 1) simpleGrading (1 0.3 1)
hex (4 6 7 5 4 6 13 12) (39 20 1) simpleGrading (25 0.3 1)
hex (2 5 8 9 10 12 14 15) (10 395 1) simpleGrading (1 25 1)
edges
patches
empty axis
(0 1 1 0)
(1 4 4 1)
(4 6 6 4)
wedge back
(0 1 2 3)
(0 1 10 11)
(1 4 5 2)
(1 4 12 10)
wedge front
(4 6 7 5)
(4 6 13 12)
(2 5 8 9)
(10 12 14 15)
patch lx_inlet
(0 0 11 3)
patch rx_inlet
(6 6 7 13)
wall top_flange
(2 3 11 10)
(9 2 10 15)
wall btm_flange
(7 5 12 13)
(5 8 14 12)
patch outlet
(8 9 15 14)
mergePatchPairs
The axis of symmetry is along X, the radius along Y and the one cell thickness along Z. The mesh is quite corse and I do get the 'Severe skewness' warning, but I still expect the solution to be qualitatively correct.
When I run the simulation, the result seem to be much like the flow between 2D flanged jets, as the velocity between the flanges seem to be constant along the radius.
I also used another file, which gives the same result, but the FRONT and BACK (wedge) palnes are parallel for the flanges and at an angle for the jets.
I am very likely doing some very stupid mistake, and would appreciate if you could help.
Regards,
Gianfilippo
gfcoppola is offline   Reply With Quote
Old   March 22, 2007, 17:57
Default Hi all, I am trying to simu
gianfilippo coppola
I am trying to simulate an axisymmetric opposed jet configuration, where each jet has a circular flange at its exit section. I am using icoFoam from FoamX and blockMesh to generate the mesh.
I am getting the right Vx profile, but a Vy=0 and Vz non zero.
Can someone comment on this, please ?
Thanks
Gianfilippo
opposed bouyancy flow(time average streamlines) Dinesh FLUENT 0 April 13, 2008 08:54
opposed buoyancy__ required help haris FLUENT 4 March 23, 2008 21:02
Flow over axisymmetric cone cylinder configuration Wamiq Rasheed FLUENT 1 May 14, 2007 13:48
PC configuration for CFD Fernando Sanz Main CFD Forum 17 December 19, 2001 07:29
opposed jets modeling Julie Siemens 0 December 9, 2001 09:16
