Coupled equations solution
Old   February 14, 2007, 06:19
Default Hi I have few transport equat
litonx
Hi
I have few transport equations which are coupled. coupling is only in the source term. Does the following method is okay.
time loop
solve(eqn1=x1*x2);
solve(eqn2=x1*x3);
solve(eqnN=x2*xn);
Does it mean sense. here eqn1..N all the transport equations of variable x1..N.
or is it possible to use a vector of length N as a variable in the transport equation. In such case, RHS would be a Matrix(N*N) and a vector(N) multiplication.
any suggestions!!
Regards -Liton
Old   February 14, 2007, 06:29
Default I think that you will have to
Gavin Tabor
grtabor is on a distinguished road
I think that you will have to solve the equations sequentially. The only issue would be if you need to loop around the transport equations because of the coupling.
Block solution would be cool, but would only be possible if someone was willing (and able) to template fvm to accept a field of arbitrary data type - something I thought about years ago but quickly decided was beyond my programming ability.
Gavin
grtabor is offline   Reply With Quote
Old   February 14, 2007, 06:43
Default Hi Gavin, Actually, you are
Hrvoje Jasak
Hi Gavin,
Actually, you are trampling all over my "work in progress" :-) This has been done recently, it is not in a public domain yet but it will eventually get there. You can get the gist from the top-level code organisation - the quoted stuff will do conjugate heat transfer in 2 regions connected by a coupled boundary conditions on the boundary. The code allows you to couple as many equations as you like, across as many variables as you like, which are then solved as a "ganged" matrix.
coupledFvScalarMatrix TEqns(2);
TEqns.hook
fvm::ddt(T) + fvm::div(phi, T)
- fvm::laplacian(DT, T)
TEqns.hook
fvm::ddt(Tsolid) - fvm::laplacian(DTsolid, Tsolid)
TEqns.solve();
Enjoy,
Hrv
Hrvoje Jasak
Old   February 14, 2007, 07:10
Default Hi Hrv. Am I right that you ar
Gavin Tabor
Hi Hrv. Am I right that you are lumping the individual matrices together? So the arrangement of data in the vector would be
(T1 T2 T3 .... Ts1 Ts2 Ts3...)
and the uber-matrix be comprised of 2 (or more) NxN matrices? Looks good. Sorting out the storage of the uber-matrix must be a nightmare though.
What I was thinking about was more basic; templating the basic matrix routines to operate on any data type. The vector then becomes a vector of subvectors
((T1 Ts1) (T2 Ts2) (T3 Ts3) .....)
and the matrix an NxN matrix of (in this case) 2x2 submatrices. This would be a really cute way of doing things - but templating the whole lot would be a nightmare.
Gavin
Old   February 14, 2007, 07:18
Default Hi Hrvoje, I can't tell you h
Ivor Clifford
cliffoi is on a distinguished road
Hi Hrvoje,
I can't tell you how excited I am to hear about the coupledFvScalarMatrix class you are working on. Its exactly what I've been looking for. Even though it's not in the public domain yet, is it available in the development version for us to start playing around with?
Regards,
Ivor
cliffoi is offline   Reply With Quote
Old   February 14, 2007, 07:49
Default Hi Hrv As I mentioned before,
litonx
Hi Hrv
As I mentioned before, I want to deal with few coupled equations, the coupledFvScalarMatrix class would help me a lot. Therefore, I have the same request like Ivor Clifford
Regards,
-Liton
Old   February 14, 2007, 13:52
Default Hi Gavin, Actually, the tem
Hrvoje Jasak
Hi Gavin,
Actually, the templating is done as well. You can now have component-coupled vector and tensor variables, for implicit div-grad-transpose terms and similar. I have done bending-dominated linear stress analysis in 1 solver call, which was the original objective.
For the things you wish to do, I'm not sure which approach is better. Multi-phase will like the matrix coupling; otherwise you have to invent new "multiple vector together" variables, which looks ugly in the top-level code. FOr example, imagine what it feels like to calculate a gradient of a variable in a compressible density-based solver (rho, rhoU, rhoE). The middle one out of 5 is a vector so a grad of this thingy is going to be ugly...
In any case, the solvers are working, parallelism is cooking and in general I am getting there. The real power is when you put all components together. As for the code, I have to say I feel a bit like the Pinball Wizzard: both are very very clean and actually tidy up a lot of existing mess as well.
Enjoy,
Hrv
Hrvoje Jasak
Old   February 14, 2007, 18:31
Default Hi Gavin, >>I think that yo
litonx
Hi Gavin,
I have written my code sequentially as mentioned early. Is it Okay. What you think. I am bit doubt that each solutions here are individual. therefore no coupling is done.
I could not understand what you want to mean?
Hrv, Could you please tell me, how to get your newly created coupledFvScalarMatrix class.
Regards -Liton
How to solver coupled transport equations chris1980 OpenFOAM Running, Solving & CFD 8 October 29, 2019 07:15
How to solve coupled transport equations nandiganavishal OpenFOAM Running, Solving & CFD 4 November 22, 2008 16:43
Solve Coupled Equations nandiganavishal OpenFOAM Running, Solving & CFD 1 November 12, 2008 22:47
Coupled solution Renaud FLUENT 3 May 24, 2006 10:39
Coupled solution Wenca Siemens 1 December 19, 2004 13:47
