January 11, 2007, 10:15 |
Dear AllOfYou,
Based on the
Thomas Jung
Rep Power: 17 |
Dear AllOfYou,
Based on the existing fixedGradient boundary condition, I am trying to implement a boundary condition for thermal radiation against an environment temperature, i.e. gradient=eps*sigma/lambda*(TRef^4-Tf^4) eps=emissivity, lambda=thermal conductivity, sigma=Stefan-Boltzmann-constant, TRef=environment temp., Tf= boundary face temp. However, I cant multiply fields (for T^4). I tried to calculate TRef_*TRef_, as a first step, TRef_ beeing declared as Field<type> ... , same as gradient. TRef_*=TRef gives a compiler error, telling me there is no operator *= taking as argument a Foam::radFluxFvPatchField<foam::vector<double> > (I made a radFluxFvPatchField from the fixedGradientFvPatchField..) No wonder, there is no such operator ... but why is my FvPatchField parameterized with Type = Foam::Vector<double> ? It belongs to a VolScalarField (Temperature), the dictionary looks like this: FoamFile { .... class volScalarField; object T; } dimensions [0 0 0 1 0 0 0]; internalField nonuniform List<scalar> ..... The boundary file like this: boundaryField { top { type radFlux; gradient uniform 100; reftemp uniform 1710; ..... So, I expected to get Type=double, and to have a field of doubles. Apparently, I have however a field of vectors of doubles. Probably I got something completely wrong ... please enlighten me ! (Btw., if I just specify the gradient, the implementation works) |
January 30, 2007, 20:26 |
Sorry if it's too late
Takuya OSHIMA
Rep Power: 20 |
Sorry if it's too late to answer. Probably it's because you're trying to instantiate the b. c. code template with <type>==<vector> within radFluxFvPatchFields.C. If you followed the fixedGradient b. c. code straightforward you might have a line something like makePatchFields(radFlux); in the file. In such case the b. c. code will be instantiated for all the scalar, vector, tensor and sphericalTensor classes. Instead you should explicitly specify only the scalar code to be instantiated by template<> makePatchTypeField(fvPatchScalarField, radFluxFvPatchScalarField); in the .C file. Hope this helps. Regards, Takuya |
January 31, 2007, 02:27 |
Yes, that was the point. I jus
Thomas Jung
Rep Power: 17 |
Yes, that was the point. I just did not read carefully enough the compiler messages.
Sorry for not posting I found it before and make you think about it - thanks a lot anyways ! |
February 5, 2007, 17:47 |
I am interested in w
Shaun Cooper
Rep Power: 17 |
I am interested in writing a boundary condition that multiplies two fields that are solved for. I want the boundary condition to set the vertical gradient of a different field equal to this product. Can you please let me know how you went about writing your boundary condition. Thankyou |
February 6, 2007, 02:37 |
Hello Shaun,
As Takuya Oshi
Thomas Jung
Rep Power: 17 |
Hello Shaun,
As Takuya Oshima pointed out: I had to use the template specialized for scalar fields, i.e. base it on fvPatchScalarField instead of fvPatchField. If I got it correctly, there is no multiplication operator for vector fields ... Good luck ! Thomas |
how can i give input for radiation problems | balaji | FLUENT | 2 | April 2, 2008 14:45 |
No matching function multiplying tensors for BC | Erik | OpenFOAM | 3 | March 20, 2008 13:05 |
Radiation in Periodic Problems | Angus Duncan | FLUENT | 0 | May 15, 2000 08:44 |
Problems with convergence and initial guessed fields in compressible steady flows | Pedro Gil | Main CFD Forum | 3 | April 25, 2000 11:34 |
Benchmark problems for radiation | achuth rao | Main CFD Forum | 0 | July 28, 1999 12:12 |
